02-27-2003, 02:22 AM | #1 |
black smoke black smoke
I am running rich and have a edelb 1405 with an electric choke any suggestions?
02-27-2003, 02:39 AM | #2 |
Is your engine basically stock? I had to detune my 1406 carb two steps to get it not to be rich. You can get the kit for about $30. It is real easy to do.
Now I am getting 15+ miles per gallon and pass the emissions with flying colors. Good luck |
02-27-2003, 02:53 AM | #3 |
how do you de tune and where can i find the kit
02-27-2003, 02:58 AM | #4 |
With your carb you should have gotten a booklet. In that booklet there is a chart that shows you what needles and jets you need to tune you carb.
You can get the kit from either Jegs or Summit. Edelbrock carbs are real easy to work with. If you need to change the jets, it might take 20 minutes. Needles take less than 5 minutes to change. |
02-27-2003, 03:01 AM | #5 |
The chart in the booklet will look like this:
My carb is now tuned at the number "7" spot on the chart. I originally went with the number '12' spot, but it was to lean. |
02-27-2003, 03:05 AM | #6 |
Check out this page for the kit you want. I guess the kit you need is $20 more than the one I needed
http://www.jegs.com/cgi-bin/ncommerc...98&prmenbr=361 |
02-27-2003, 03:18 AM | #7 |
Recovering Truck Driver
I was hoping we were talking about diesels!!!!!
67 K-20 350, SM465, Eaton rear, 4.56 no spin option 00 Dodge 2500 4x4, 24V cummins, 5 speed Chad South Central Nebraska |
02-27-2003, 04:06 AM | #8 |
I'll just put it this way.....any diesel I ever had, automotive or semi truck rolled black smoke like a housefire........Who ever would have dreamed that a screwdriver could create so much torque !!!!!!
02-27-2003, 09:09 AM | #9 |
Is the choke opening?
Tim |
02-27-2003, 09:16 AM | #10 |
r u running a pressure regulator.even with a stock pump u need one those edelbrocks dont like more than 5.5 psi and ur stock pump is probably running somewhere between 6 and 9 psi.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
