Old 10-03-2010, 11:11 PM   #1
hilandr452
hilandr452's Avatar
Engine Upgrade on my 71 !
OK so it's time to retire the 402. It has low power, leaks everywhere, and needs to be rebuilt and given a good home. The carb is a quadrajet and it has stock intake.
I have an 83 one ton GMC with a 454 that only has 10k miles on it after rebuild that I used to use as my camper. It is wrecked on the side you don't see here and it will be the donor truck.
Here's the donor engine being repainted.
All shiny with the headers on and on the engine stand.
About a year ago, I replaced the turbo 400 with a rebuilt one out of a chevelle. The speedo hasn't worked since then, so I pulled it with the engine to bench it and figure out why. The drive worm gear on the tail shaft was missing, so I replaced it with the old one I still had. Those little clips are wierd so I looked it up and saw that all you have to do is hold the spring clip down and slide out the gear.
With the tranny fixed, I bolted it up to the new motor.
Heres the truck sans motor.
and the installation...
Look at this mess!!!
I added an Edelbrock performer and an Edelbrock 750 CFM square bore carb, same as Carter AFB.
Well, that's the story so far, I need to install the headers and fab the exhaust a little to fit. Then finish up with the radiator and all hoses and fuel lines. I'll let you guys know how it runs!
See you soon!
Dan
Dan Smith
Colorado Springs, CO
71 GMC Custom Camper "Longhorn" 454, TH400
73 Chevy Camper Special (Yes, it's badged a camper special) Flat Bed Motorhome conversion 454, standard tranny
"DON'T TREAD ON ME !!!"
My Project: http://www.picturetrail.com/sfx/album/view/20829244 , http://www.picturetrail.com/sfx/album/view/24654442
hilandr452 is offline   Reply With Quote
Old 10-04-2010, 12:48 AM   #2
El Jay
Gone to greener pastures
Re: Engine Upgrade on my 71 !
looking good!
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 10-04-2010, 01:47 AM   #3
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Looks like it should be fun! I'm am considering dropping a 454 in mine, but right now I have too many other (non-truck) projects going on. Good luck and let us know how it runs.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 10-04-2010, 02:13 AM   #4
Rat Bastid
Rat Bastid's Avatar
whats up with the tired 402??
Rat Bastid is offline   Reply With Quote
Old 10-04-2010, 07:59 AM   #5
hilandr452
hilandr452's Avatar
I'm not sure what you mean?
Dan Smith
Old 10-04-2010, 09:22 AM   #6
gearys 5600
gearys 5600's Avatar
I am pretty sure he means, what are you gonna do with it ?
I am not intersted in it, just trying to help out.
MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=423629
1969 custom/10 swb--SOLD
1968 swb 50th anniv.--SOLD
1967 camaro ss/rs..LS-6-speed, 16-year long project
1956 chevy nomad
1955 chevy 210 2-dr sedan
1978 el-camino ss 1-owner
gearys 5600 is offline   Reply With Quote
Old 10-04-2010, 09:24 AM   #7
6772owner
Gearhead
6772owner's Avatar
Hilandr452,
That is awesome buddy, glad you got the swap done! Looks great, how does it run now?
2002 Saturn SL2, My D/D
2019 Ford Fusion SE, Ecoboost - Wife's D/D
1993 Camaro Z28, A4, CAI, Cat-Back Exhaust
Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD!
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644
6772owner is offline   Reply With Quote
Old 10-04-2010, 02:38 PM   #8
Ticker
Looks great!
Ticker is offline   Reply With Quote
Old 10-05-2010, 01:52 AM   #9
hilandr452
hilandr452's Avatar
OK, my son and I put on the headers, installed the alternator and power steering pump, hooked up all the lines, added coolant and oil, but were only able to hook up one exhaust pipe to the headers, the drivers side header is canted up slightly, so theres a 1/2 inch gap. Looks like I'll be welding pipe tomorrow.
I fired it up for like 2 seconds just to see if she'd go and she did, but it was 11 pm so I quickly turned it off. That open header is LOUD!!!!!
I'm too tired to upload the photos, so I'll catch you tomorrow.
Dan
Dan Smith
Old 10-05-2010, 10:07 PM   #10
hilandr452
hilandr452's Avatar
Here's a pic of my boy workin' on the truck.
Putting on the plug wires.
Passenger side header tube lines up, but driver's side is canted up.
Two sawzall batteries, some upside down welding, and a day later and it's all good!
Final product minus the aftermarket air cleaner I have to go buy.
Well, that's it folks, the truck runs like a bat outta hell now. Took the wife for a spin tonight and it really flies!! Turns out the old transmission modulator vacuum line was leaking bad and with the new line in place it shifts like a dream.
Now I just need those 16 x 10 inch steelies, a new tail gate, bed side, new bed wood, new seats, a bunch of body work and a paint job.....
At least I won't be bored!
Dan
Dan Smith
Old 10-06-2010, 09:10 AM   #11
6772owner
Gearhead
6772owner's Avatar
Thats awesome buddy, glad you got it all sorted out, now drive the wheels off of it!
Old 10-12-2010, 11:16 PM   #12
hilandr452
hilandr452's Avatar
Figured I'd post the problems I had after the swap. First off, the upper hose clamp wasn't tight enough and leaked coolant. I took off the radiator cap to fill it up again.
Then I took it for a spin down the road a ways to check for speed. Stopped at a light and steam was coming out from under the hood again! I had forgotten to put the cap on and boiled 4 gallons out onto the street.
After filling the system again, we went for a ride and there was a bad vibration at 35 mph, then again at 55. Looked underneath and the passenger side header was hitting the frame, so I notched it slightly. (the frame!)
While working on this, I noticed a small leak in the seam of the end cap of the radiator. Removed the radiator, flushed with fresh water, melted off the end cap solder, then added flux to the entire seam and sweated solder into the seam again properly.
Vibration is lessened but still there, so I changed the motor mounts. (I know, should have done that in the first place!) Now she's running perfectly.
Listen to the almighty forum Gods when they say things like "Change the Motor mounts every time you remove the engine, they're 7 bucks a piece." or "Make sure you check the radiator cap before you close the hood."
This is good advice!!
Dan
Dan Smith
Old 10-12-2010, 11:27 PM   #13
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Awesome you got it all in there and running good. The little stuff is just that. Little stuff. Glad you have her back on the road and you are happy with the swap.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 10-13-2010, 12:34 AM   #14
Ed 72 Sierra Grande
Ed 72 Sierra Grande's Avatar
Great Job!!!
Inquiring minds want to know where the tired 402 is going?
Ed F
1972 Sierra Grande
White Top Medium Olive
402 bb / Camper
Stock, Loaded, Straight & Aged Nicely, No Tilt
Original Resto would be nice $
Ed 72 Sierra Grande is offline   Reply With Quote
Old 02-06-2012, 12:32 AM   #15
hilandr452
hilandr452's Avatar
Hey guys,
Thought I would share how things are going and update the build. We've moved from Colorado Springs to Penrose, 35 miles south from the city to a small homestead where I have more room for my toys and a pasture for my daughter's horse. The truck has been running fantastic the whole time. I pulled a 2 axle horse trailer full of all my crap about 20 times back and forth between the two cities with no issues except horrible gas mileage.
My brother sent me Custom Camper badges for my truck and I don't know the exact placement for them so I'll need some of you to post pics for me please.
One problem that has never gone entirely away is the vibration. I changed all the mounts including the tranny, but there is still a nagging vibration there at idle, and at certain rpm increments. I've been giving it some thought and i have an idea about what it might be. The engine I installed was from a 1 ton dually which was a standard transmission with a huge hulking clutch plate. It occurred to me that since they have this huge balanced clutch plate instead of the flex plate which is now on it, that there might be a difference in the stock harmonic balancer between automatic and manual applications. Can anyone tell me if there's a difference?
Oh, and FYI I still have the 402 on an engine stand in my new garage.
Thanks guys,
Dan
Dan Smith
Old 02-06-2012, 12:50 AM   #16
dukcaln
dukcaln's Avatar
nice.............. big block power
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP
SOLD 1972 chevy c10
dukcaln is offline   Reply With Quote
Old 02-06-2012, 06:28 AM   #17
trev1
454=torque=terrible gas mileage....But fun has no price IMO..
Good job. On the swap. As far as the vibration. Is the driveshaft indexed? I would check the U joints. Sounds like one is giving up the ghost.
trev1 is offline   Reply With Quote
Old 02-06-2012, 08:09 AM   #18
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
Dan, where did you get the flex plate that currently is on the 454? The 454 is externally balanced & requires an externally balanced flex plate (or flywheel in the case of its previous life in the 83 1 ton). The lack of that wee little balance weight on the flex plate will give you a bunch of weird vibes for sure...
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
Old 02-06-2012, 02:32 PM   #19
hilandr452
hilandr452's Avatar
Flex plate came off the old 402, which I don't remember having a vibration issue.
Dan Smith
Old 02-06-2012, 03:15 PM   #20
68c20lwb
68c20lwb's Avatar
you will probably require a new flexplate, the one off the 402 was not balanced like the one on the 454 should have been. you need one off of a 454 or one built for a 454 with the external balance
1968 C20 450hp 425ft-lbs 454/SM465 4.56's 2004 HD rims, needs paint and a 5th gear!
1969 C30 Open Road Motorhome 350/th400
1972 K10 350/350/205 Daily Driver -SOLD
68c20lwb is offline   Reply With Quote
Old 02-07-2012, 02:31 AM   #21
passthebuck
External balanced:
http://www.summitracing.com/parts/SUM-G102SFI/?rtype=10
Vs.
Internally balnaced:
http://www.summitracing.com/parts/SUM-G100SFI/?rtype=10
See that weight welded on to the externally balanced one? Thats what you're missing. A relatively easy fix, it's just going to involve pulling the transmission to change out the flexplate.
http://www.eaglerod.com/index.php?op...d=27&Itemid=25
passthebuck
#5642
Old 02-07-2012, 11:56 AM   #22
406 Q-ship
406 Q-ship's Avatar
402 is internal balanced, 454 is external balanced. Do not drive/run the truck until you change out the flexplate for one the is for the 454. You did use the balancer off the 454....right? The balancer must be extrenally balanced on a 454 just like the flexplate. It can kill the crank and or bearing in the engine if you keep running it with the wrong flexplate.
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride!
Where patience fails, force prevails
Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle."
406 Q-ship is offline   Reply With Quote
Old 02-07-2012, 02:00 PM   #23
hilandr452
hilandr452's Avatar
I did keep the harmonic balancer from the 454. I've been driving it this way for over a year, recently hauling a trailer for the move. Guess I'll tear it back down.....
Thanks for the help guys!
Dan Smith
