Old 10-04-2010, 12:26 AM   #1
Shaffer4
Strange Cousin From The West..
Rear window crank/lock question.
Just picked up a '78 K5 (pics to come) and the rear window doesn't roll up, but the lock cylinder is missing. I was wondering if the roller doesn't work without the cylinder, as I know some of the older SUV and Wagon rear rollers have the "free" position.
Shaffer4 is offline   Reply With Quote
Old 10-04-2010, 12:47 AM   #2
68Timber
I know the pieces fit
68Timber's Avatar
Re: Rear window crank/lock question.
yep...
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 10-05-2010, 07:54 AM   #3
motornut
78K & 79C Jimmys
motornut's Avatar
yup had to wire up a burb window till i got the parts......
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 10-05-2010, 09:29 AM   #4
48cj2a
48cj2a's Avatar
Is it power? My Manual crank CUCV still works up and down without the cyl.
I just pulled a regulator and lock from a pwr Blazer, When I unsrewed the cable from the motor I was able to raise and lower the regulator by hand turning the cable with my fingers (glass was removed). A cordless drill may work with the window still attached to at least get it back up if thats what your after until you get a lock.
Anyone know if the lock is recodeable to a different key?
03 Suburban Z71 Z71
98 GMC Yukon SLT 4x4 Yukon
86 M1009 CUCV Project Milverado
48 Willys CJ2A 48CJ2A
48cj2a is offline   Reply With Quote
Old 10-05-2010, 11:46 AM   #5
68Timber
68Timber's Avatar
I had to replace the lock cylinder on my rear window, I had a local locksmith fix it to match the door locks.
John
74 Honda Z50 build
Old 10-06-2010, 01:14 AM   #6
Shaffer4
Manual Crank. Previous owner used it as a "pickup" plywood/plexiglass divider and all. Haven't had a chance to look into it, as I've been busy getting it road worthy.
