Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Closed Thread
Old 10-04-2010, 02:21 PM   #1
1ATony
02-06 Suburban C1500 Blower Motor Resistor FRONT for Models with 4 Hole M
CHECK LINK BELOW FOR CURRENT PRICING
2002 - 2006 Chevy Suburban C1500 Blower Motor Resistor FRONT for Models with 4 Hole Mounting Flange
This GM Truck & SUV blower motor resistor is a new, aftermarket replacement part. It is just what you need to bring your heating and A/C blower system back to good working order! On most vehicles it is mounted to the HVAC unit inside the passenger compartment. It can be accessed from the passenger foot well area.
Specifications:
New, not remanufactured or rebuilt
Direct replacement
Replaces dealer part numbers: 89019088, 15-81086
Built to strict quality control standards
100% tested prior to leaving the factory
7 & 2 Terminal connection
4 bolt mounting flange
For models that have a front and a rear blower motor, this replaces the FRONT RESISTOR
Note: For 2007 truck models, the Classic Style has a crease down the center of the door skin where on the new body styles, the door skin is smooth. This part is for the Classic style truck.
If you are experiencing intermittent stopping during use or the fan only works in one position this may be your solution!
This part replaces:
OE #: 89019088
1ATony is offline
Closed Thread
