Old 10-04-2010, 04:32 PM   #1
05crewcab
05crewcab's Avatar
ignition switch...bare minimum needed to operate?
Which wires are the bare minimum needed at the ignition switch to start the truck and turn it off? Is it just the red and purple wires, or more?
and, what wouldn't be energized in "on" if I leave the other wires out?
1971 C-20 350/350
05crewcab is offline   Reply With Quote
Old 10-04-2010, 04:51 PM   #2
tkeduk8r
tkeduk8r's Avatar
Re: ignition switch...bare minimum needed to operate?
In jyards I look at the color of the wires that lead to the starter solenoid and ignition coil and match them to the color wires on the ignition switch plug. Then you will need to break a paper clip in two and jump the main hot (red heavy gauge wire) to the coil wire and then take the other half and put one end in same hot wire and "tap" the other end into the yellow or purple solenoid wire.... You also may have to runa ground jumper from the switch plug to ground as well... its been a while, but it has never failed me yet....
--Mike
63 C20 2WD, 230/SM420/4.11 73K
68 C30 dump truck, 327,SM425,4.56 66K original
68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes
68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79
69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi...
70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP
72 Chevy K20 4x4 350/350/205/4.56 donor
72 Vette 350/M21/3.70 posi, triple black and super fast
84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's
tkeduk8r is offline   Reply With Quote
Old 10-04-2010, 05:20 PM   #3
05crewcab
05crewcab's Avatar
Thanks for the response Mike, but I am still confused
I went to O'Reilly's and bought a cheapo ignition switch w/ keys.
It has 4 terminals:
Batt
Ignition
Acc
Starter
I assume that the wires should go like this:
Batt = Red
Ign = Pink
Starter = Purple
Acc = ???
Does this sound right?? There are way more wires than just 4 going to the factory switch...
1971 C-20 350/350
Old 10-04-2010, 06:17 PM   #4
raycow
If you have a brown, connect that to ACC.
Ray
raycow is offline   Reply With Quote
Old 10-04-2010, 06:22 PM   #5
too much stuff
Roadtrip!
too much stuff's Avatar
Just grab the switch from your other truck, plug it in and go...
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 10-04-2010, 09:37 PM   #6
05crewcab
05crewcab's Avatar
I would pull it from my other truck, but it works well and I don't want to funk with it, plus the pigtail on the 'new' truck is melted kinda bad so I am sure something else is wrong too.
1971 C-20 350/350
