Resident Lurker
Filler Ideas for Blazer Tank?
With the steel blazer tank I got from CPP installed, there is no room between the filler neck and the bottom of the bed floor. There is only about 2" between the frame and bed floor and the filler sticks up about that same amount. I was hoping to attach a filler cap just under the floor and use a billet gas door mounted flush on the top side, but not sure that's possible now without a lot of tedious cutting and welding.
I'd like to see some ideas on how others tackled it. Btw, mine is a stepper.
The Rotten Mule: '72 Chevy Short Step Project- http://67-72chevytrucks.com/vboard/s...d.php?t=417252 "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats."- H.L. Mencken |
![]() Join Date: Jan 2001
Re: Filler Ideas for Blazer Tank?
What about using one of those stainless screw-on boat ones and stick it right on the bed floor?
i dunno... |
Resident Lurker
I thought of that, but with the bed on, there isn't any room to access the fuel neck at the tank to tighten the hose clamps. There's gotta be a way, I've seen plenty of pics with the fuel filler in the bed floor...I just can't figure out how to do it with such a small amount of space to work with.
Grandpa in the rustmobile...
drop the tank weld up the stock hole cut a hole and mount a filler neck where you want on the top of the tank is what i would do if I could do it again, im routing mine thru back up light, but mines fleetside... try a search
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
Has more rust than truck...
Side marker light fill.
http://67-72chevytrucks.com/vboard/s...&postid=599699 Click on my build thread for some more pics and info. |
Resident Lurker
Thank you sir. On another note, where can I find fuel filler hose? I've been to AutoZone, Pep Boys, Napa, and O'Reilly's and none of them carry it, at least locally.
My 1.25"id fuel/exhaust hose came from a specialty hose store. You could also try building up the filler neck with jbweld and use more availible 1.5" hose.
good luck, I couldnt find anything smaller than 1 1/2", and that came from Napa..
