10-04-2010, 08:11 PM | #1 |
Old and crusty
Dropped spindle issues
I just installed the CPP 2 inch drop modular spindles and disc brake setup along with stock height springs. All the steering components are new Moogs and the control arm shafts are also new Moog. I used the same alignment shims that came out of the stock setup untill it goes to the alignment shop.
I then decided to get it close and set the toe in at about 1/8 inch and just checked with a level on the wheels to look at the camber because the pass side looked like it was way in at the top. The driver side has a slight amount of negative camber but the pass side has a ton. I backed out the nuts all the way on the upper control arm shaft and could not get it as close as the driver side. I'm afraid that the holes in the spindle are not machined correctly or am I just being too anal about this before I get any load on the frame? At this point there is no weight anywhere on the frame (no cab, box or running gear. What do you all think? Thanks for your comments in advance. Dean |
10-04-2010, 08:31 PM | #2 |
Never Ending Projects
Re: Dropped spindle issues
Don't assume anything until you are back on the ground, full weight and have rolled it a few feet to allow the suspension to "settle" into it ride position. Just set things the way they were prior to changing the spindles and let the alignment shop check things.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
10-05-2010, 10:08 AM | #3 |
Old and crusty
That's probably what I'll do although when I mention dropped spindles to the alignment guys around here I mostly get a lot of negative comments.
Any other opinions/comments anyone? |
10-05-2010, 10:39 AM | #4 |
It's Better With Nitro
The suspension will need to have all of the vehicle weight sitting at ride height before making adjustments, etc.
10-05-2010, 09:20 PM | #5 |
Old and crusty
OK I guess I'll check it out after I get some weight back on the frame. Thanks, guys.
05-04-2011, 06:44 PM | #6 |
Any updates? How did it work out?
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
05-04-2011, 07:18 PM | #7 |
Yea, update us ,did it work out for you ?
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
05-04-2011, 11:47 PM | #8 |
Just have yourself a freshy. it will fix everythang
