![]() Join Date: Oct 2009
Brake rod pictures for WEBBES
Here is a picture of the part that connects the brake master cylinder rod to the brake pedal arm.
Note: All parts I have for sale are also for sale locally. I currently own: 1940 Chevy Fire truck (project), 1946 Chevy truck (project), 1946 Chevy 1 Ton pick up, 1953 Chevy school bus (storage area), 1968 Chevy C10 (I have drove for 26 years), 1994 Chevy C2500 (daily driver), 2005 GMC crew cab K2500 (parts hauler) and more trucks for parts. |
86 Scottsdale
Re: Brake rod pictures for WEBBES
and if you're looking to fab a rod, you need about a 1 ft long piece of 7/16-20 (if memory serves correct) threaded rod to screw into the long piece.
86 Scottsdale
I think mine ended up about 11 inches total length, and I used a grinder to taper the end that went into the master cylinder. Just make sure you get it centered in the bore so it doesn't bind. Once you get it adjusted, tighten down the jamb nut and drive.
Sorry I did not explain better but WEBBES has a rod that came with a brake kit but it did not come with the pedal end so I was showing him the pedal end of the rod. Thanks for the information. Todd
86 Scottsdale
I had the exact opposite happen. My trucks PO had butchered the part that passes into the firewall, and had a 2 year old weld it back together crooked about an inch from where it passed through.
