Old 10-04-2010, 08:56 PM   #1
GobbleStalker
GobbleStalker Calls
GobbleStalker's Avatar
5 lug pattern & offset?
I have a 72 lwb and am starting to look into rims but I do not understand the off set and spacing I need. Factory 5 bolt with disc up front and leaving the drums on the back. Looking to go 17 or 18 " rims. Thanks in advance for the help.
Kev
72 Chev Longbox Highlander edition. Med Olive/White/ Med Olive 350 4bbl with 350Turbo trans. Truck currently under construction. Project Cappaccino.
Stay Tuned!
1967 Chevy C10, 327, 4.11 posi 3 spd. The Driver Truck! SOLD!
09 GMC Sierra SLT All Terrain pkg.
2014 Jeep Wrangler Sahara unlimited. ( The wifes ride )
GobbleStalker is offline   Reply With Quote
Old 10-05-2010, 09:31 AM   #2
68Stepbed
68Stepbed's Avatar
Re: 5 lug pattern & offset?
Offset isn't as important as backspacing. Backspacing(bs) is the distance from the back edge of the rim to the flat surface where is sits against the hub.
In general, an 8" wide wheel works best with 4-4.5" of bs.
A 9.5" wheel works well with 4.75-5.5" bs.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 10-05-2010, 09:55 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
and the bolt pattern is 5 on 5
Old 10-05-2010, 10:14 AM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by GobbleStalker View Post
... Looking to go 17 or 18 " rims...
As your shopping for wheels, take a look at tires sizes and prices too. I have found that it is better to ensure that the tire sizes are available at a fair price. These days 17's are common and 18's aren't as much. You will find a much better selection in 20's and the price will surprise you as being as cheap if not cheaper in some cases.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
