10-04-2010, 09:35 PM | #1 |
Jeep Springs
I have been reading on here where a lot of people are using Jeep springs to get a 4" + drop. If you used them did you have to modify the spring retainers because mine bottom out before they get tight on the spring, and exactly how much drop did you get? I got a set given to me and I am trying to figure out if I want to try to use them or just buy some 4" drop springs. Any thoughts and tips would be greatly appreciated.
10-05-2010, 08:22 PM | #2 |
Re: Jeep Springs
So I take it that no one is running Jeep springs.
10-17-2010, 02:00 PM | #3 |
Re: Jeep Springs
i've got a set to, but haven't had time to install them yet
10-17-2010, 07:19 PM | #4 |
At the body shop.
Re: Jeep Springs
I understand its more for drag racing, more stored energy
" That didnt make it any newer " " Dont antique the equipment " |
10-17-2010, 07:34 PM | #5 |
Re: Jeep Springs
I have a set and am using them. On a jeep, so not much help but if you need pix on how they are mounted i could take some when i am out at my shop on Thursday. It's a 79 cherokee if that helps.
Pm me Thanks, Steve |
10-17-2010, 10:35 PM | #6 |
Grandpa in the rustmobile...
Re: Jeep Springs
Im running them
late 90's TJ rears You cant haul much with em, they do bottom out with the retainers, I havent worked that out yet..You can make your own shock relocators, and adj panhard bar also, post back if ya interested.. I may swap mine back out for stock, caues i use my truck as a truck too much to justify the awesome stance..
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
10-17-2010, 11:07 PM | #7 |
Re: Jeep Springs
Is this for front or rear?
Ray |
10-18-2010, 07:39 AM | #8 |
Re: Jeep Springs
I'm using the TJ springs on my 64 in the rear,I only got a 3" drop but I like it. Haven't tried hauling anything in it as I don't use it as a DD. The spring retainers bolted right up No problem.
10-19-2010, 09:49 AM | #9 | |
Re: Jeep Springs
M5 |
10-19-2010, 07:33 PM | #10 |
Re: Jeep Springs
^Good idea about the hammer, will do mine next time they are off
