10-04-2010, 10:00 PM | #1 |
Lift it 4" or 6"?
Hey guys, this is my first post in the 4x4 section. I'm trading my '85 K30 cc dually for an '89 V1500 suburban (Can't afford the 7 mpg as a daily driver and need a car I can fit the kids in) that I'm planning on setting up for expedition type trips. I will use it to pull my '17 camper (2800 lbs) and for various types of wheeling. I want to set it up to take maximum advange of articulation so no giant lifts with huge tires. I also don't want to cut the fenders. I'm also going to start acquiring the parts to do a cross over steering setup. I'm torn as to which will give the me the best articulation in the field, 4" or 6". Let me know what you all think.
1978 GMC Jimmy, 400, th350, np203 with part time conversion, Fibrecraft popup camper, soon to get a 14 bolt/d44 swap 2001 Yukon XL2500, 6.0, 4L85E, 4x4, family truckster |
10-04-2010, 11:38 PM | #2 |
Re: Lift it 4" or 6"?
The best way to go would be to get a B52 front spring set up from DIY4X.com then on the rear go with a shackle flip kit from offroaddesigne.com. The B52 puts 52 inch rear springs on the front. If you use factory springs you will get about 4 inches of lift and massive flex.
82 c10 5.3/4l60 84 c20 5.3/sm465 85 chevy k10 suburban LQ4/4l60 91 chevy c10 suburban Lsa 5.3/4l60 2017 Silverado whipple 5.3 1964 Vw beetle 1974 vw beetle |
10-05-2010, 10:18 PM | #3 | |
Certified Hobbiest
Its does require a bit more work than a tradition lift but the benefits are great. Posted via Mobile Device |
10-05-2010, 11:02 PM | #4 |
i dont think i'd go w/ 52's & flip if you plan on towing but for best articulation.....
i've got Burb, 6" w/ 35's & lockers & had to trim lower 8" rear of front fender to wheelwell so tire didn't rub it. plus i've longer shox w/ ford shock towers. xover helps ALOT. sure can't steer stock w/ tire all jacked up , especially w/ a locker i'm not running any swaybars & tow quite a bit. i'd rather go 4" & longer shock + trim more sheetmetal than 6, if I had to do it again.
http://www.cardomain.com/id/Schralper Last edited by Schralper; 10-05-2010 at 11:04 PM. |
10-06-2010, 12:40 AM | #5 |
Certified Hobbiest
i hear that a lot with the 52/shack flip with hauling but i dont see why that would be an issue. (ideas as to why it would?)
i know a few guys that run that set up and they haul with no problems. cross overs a must with anything over 4" imo |
10-06-2010, 01:35 PM | #6 | |
Towing = stiff I just don't see a lotta rock crawlers towin. Are ya crawlin or towing? 52's aren't such a problem, just lotsa work to install. http://coloradok5.com/52inchspringswap.shtml great if ya REALLY need the flex If just wheelin, flip, but the added stress on rear hangers when towing.... You could reinforce hangers w/ some .125" plate. Now if you're just towing a lil load to the dump, no problems but what if ya gotta swerve or some other evasive maneuver..... soft tire sidewalls are bad enough. I see peeps driving w/ a load of wood w/ the rear bumper draggin & the headlights angled for squirrel hunting. They seem to haul fine until something happens. I sure the heck don't wanna be around it when an overloaded p/u starts fishtailing.
http://www.cardomain.com/id/Schralper Last edited by Schralper; 10-06-2010 at 01:38 PM. |
