Old 10-04-2010, 10:49 PM   #1
3r!c84
Badass
3r!c84's Avatar
what is this?
what is this and do i need it?
84 c10 305/th350c was on the pass top fire wall. has a vacuum line hooked up to it.
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 10-04-2010, 10:54 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: what is this?
Torque converter lock/unlock
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 10-04-2010, 11:01 PM   #3
3r!c84
Badass
3r!c84's Avatar
Re: what is this?
so i still need it, i relocate it tho
-00 Saturn 5spd
1/4:13:90
Old 10-04-2010, 11:25 PM   #4
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: what is this?
Torque converter lock up is the driverside wall. The one on the passenger is part of the ESC system.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 10-04-2010, 11:27 PM   #5
3r!c84
Badass
3r!c84's Avatar
Re: what is this?
dont need one like this on the drivers side? and whats ESC system? do i need it
-00 Saturn 5spd
1/4:13:90
Old 10-04-2010, 11:44 PM   #6
nbpro
Re: what is this?
ESC system Electric Spark Control
converter lock/unlock is part of the 350thc
nbpro is offline   Reply With Quote
Old 10-04-2010, 11:57 PM   #7
3r!c84
Badass
3r!c84's Avatar
Re: what is this?
im going to be running a msd system so i wll not be needing the ESC then?
and i didnt see anything like that on the other side for the converter lockup
-00 Saturn 5spd
1/4:13:90
Old 10-05-2010, 12:04 AM   #8
3r!c84
Badass
3r!c84's Avatar
Re: what is this?
better pic to see where its at
-00 Saturn 5spd
1/4:13:90
Old 10-05-2010, 12:24 AM   #9
nbpro
Re: what is this?
Try circling it, because I can't tell from that pic. It's a possibility that someone bypassed your's. Is that a stock carb you're running?
Old 10-05-2010, 12:27 AM   #10
scottsdaleowner75
Re: what is this?
By chance can you take a pic of where the vacuum line goes to? I have the same thing on my 86's but i dont know where the vacuum hose goes
scottsdaleowner75 is offline   Reply With Quote
Old 10-05-2010, 12:28 AM   #11
nbpro
Re: what is this?
http://www.msdignition.com/forum/index.php?
http://www.73-87.com/7387garage/drivetrain/escrepl.htm
Old 10-05-2010, 05:10 AM   #12
gchemist
gchemist's Avatar
Re: what is this?
Here is a better picture from my 83 original configuration.
I removed it along with all the ECS wiring harness.
Look straight up from the top left corner of the brake oil cover. Right above it is the lock switch for a 700R4. The red wire goes around it. The lockup switch is on the bottom right corner of the fusible link junction open box.
Old 10-05-2010, 11:14 AM   #13
3r!c84
Badass
3r!c84's Avatar
Re: what is this?
it has a stock carb i will not be using the stock carb with the new motor
ive got TH350C so there should be a lockup converter switch instead. what consists of the whole ESC wiring harness?
-00 Saturn 5spd
1/4:13:90
Old 10-05-2010, 12:45 PM   #14
dropd80s
dropd80s's Avatar
Re: what is this?
As best I rememeber, everything coming out of the large grommit directly behind the motor (slightly towards the pass side) should be the ESC harness. Should have a plug for the dist., knock sensor wire, ect. Inside it will run to a small box like a computer. Unplug the harness from the box and remove.
dropd80s is offline   Reply With Quote
Old 10-05-2010, 12:48 PM   #15
nbpro
Re: what is this?
Complete 73-87 Wiring Diagrams
Old 10-05-2010, 01:25 PM   #16
3r!c84
Badass
3r!c84's Avatar
Re: what is this?
Sweet thanks I'll check it out when I get home it's hard on my iPhone
-00 Saturn 5spd
1/4:13:90
Old 10-05-2010, 10:24 PM   #17
3r!c84
Badass
3r!c84's Avatar
Re: what is this?
ok i looked over the diagram and it said nothing about the ESC system or about what i had.
-00 Saturn 5spd
1/4:13:90
Old 10-06-2010, 12:16 AM   #18
gchemist
gchemist's Avatar
Re: what is this?
Go to www.autozone.com. You'll find emissions diagrams there with the switch.
Old 04-16-2011, 10:52 PM   #19
Alan_S
Re: what is this?
I have a 1986 c10 with a 1970 307 and turbo 350 I saved the truck from being a parts truck and installed the motor. In a nutshell I have a torque converter lock but I have no idea where the line goes to even after looking at the picture above and buying a book at the auto parts store. I do have two of them it appears and the ball and some lines but I need some advice on where they all go. My motor is simple I have the basic motor and carb no sensors for smog or emissions are installed.
Alan_S is offline   Reply With Quote
