Old 10-05-2010, 03:48 AM   #1
low&slow
Are there any car chassis the a '69 body will fit on?
I have a '69 chevy c10 long bed and I'm on a very low budget as of $0.00. I've done a lot of work to it already from where it started from, but now I'm wanting to lower it. My idea is still flowing through my mind pretty fresh still. I wanted to put it on a '69 camaro chassis. Make it wider to fit the body and possibly longer. Wondering if it's possible?
low&slow is offline   Reply With Quote
Old 10-05-2010, 04:55 AM   #2
mcmlxix
Collector of Projects
mcmlxix's Avatar
Re: Are there any car chassis the a '69 body will fit on?
No. 1969 Camaro is a unibody car with a front subframe that bolts on.... and anything with "69 Camaro" mentioned will usually cost more then 69 truck parts.... the cheapest way is to cut the springs.... ONLY a small amount at a time....
Rich
1972 K5 Blazer CST Click HERE
Old 10-05-2010, 05:11 AM   #3
low&slow
That makes sence. Aside from camaro, is there any car chassis that would work for '69 year body?
How do you go about cutting the springs so there exactly even?
Old 10-05-2010, 05:18 AM   #4
mcmlxix
mcmlxix's Avatar
Take them both out. Set them next to each other on the ground to the ends are located the way. tape off a mark where you want to cut them... never more then 1/2 coil at a time.... then reinstall and see it sits low enough for you... labor intensive.... AND ALWAYS BE CAREFUL WHEN WORKING WITH COIL SPRINGS... They are under alot of pressure...
I dont think there is a chassis from anther vehicle that will be worth the swap. Its all old technology that needs to be upgraded.... just work with what you have....
Rich
Old 10-05-2010, 05:29 AM   #5
low&slow
Alright. By the way thanks so far for the help. Just a 17 yr old kid trying to learn as much as possible. Very determined.
How do you get the springs out and put back in properly?
Old 10-05-2010, 12:51 PM   #6
Danny Bost
Danny Bost's Avatar
I was planning to set my 71 short bed on a 1991 Caprice chassis. Same track width and less than half an inch of wheel base difference. I have been building custom cars for 20+ years and when I really started looking at the work that was involved I decided to stick with my truck frame. Is your truck coil spring rear? If so you can lower the rear using Jeep Wrangler springs. The rear springs on the truck are not real safe when you cut them. If you use the Jeep springs it is supposed to give you about 4 inches of drop. I would cut the front springs as advised if I didn't have the money to buy drop springs. Whatever you do good luck.
Danny
71 SWB
Danny Bost is offline   Reply With Quote
Old 10-05-2010, 12:56 PM   #7
1LoC10
Insert Title Here
1LoC10's Avatar
No trying to be rude at all....but if you have to ask how to cut springs, do you really think you will be able to swap the body on a different chassis?
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 10-05-2010, 12:58 PM   #8
71swb4x4
71swb4x4's Avatar
Cutting the front springs is the cheapest way to drop the front.
Putting blocks in the rear is an easy way to drop the rear.
You can't cut rear springs. They are pigtailed and bolt to the frame and to the trailing arm.
Parts for these trucks are relatively inexpensive. There are used parts out there too if you keep your eyes open. Used springs and drop spindles generally don't stick around long.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 10-05-2010, 01:07 PM   #9
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
While I can see where a 17-yr old mind is headed in thinking as you do, you may be unaware that the trailing arm design of these trucks (60-72), with coil springs, is a design that NASCAR adopted for their racecars. Of course, there are some tweaks but the basic design is the same.....and the principle is the same.
If you have leaf springs, the rear end configuration is different. But, you already knew that, didn't you?
Member Nr. 2770
Old 10-05-2010, 01:20 PM   #10
ctrow
New Member
ctrow's Avatar
I'm all for learning as we all started out somewhere. Asking is the best thing to do before just tearing it apart.
As for this topic, find someone local that can help you with this. Maybe there will be a forum member that would be willing to assist you. There's a couple of ways to get the spring out. It's probably best to have someone with some knowledge before you tackle this just to be safe. Plus you'll learn other tips and tricks that you might not see in a forum.
On the other side, assuming you have transportation, drive it like it is until you can afford the necessary components. It will work to cut the springs but not the best method.
Best of luck to you though.
My Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=366351
ctrow is offline   Reply With Quote
Old 10-05-2010, 01:33 PM   #11
96blazr
96blazr's Avatar
Do yourself a HUGE favor; ECE (Early Classic Enterprises) has 2" dropped Coil springs for the front @ $114.00 a PAIR.
And they have Dropped Rear Springs, from 1" to 6" drop, for the Rear @ $114.00 for a PAIR.
Buy one Pair now, save for the other pair, then install all at once. It'll save you a lot of headaches in the long run, not to mention the safety factor of cutting springs.
http://www.earlyclassic.com
1968 SWB.
GMPP 350/350 Turbo Trans, Edelbrock Performer & Carb. Hedman Hedders, Hooker Aerochambers Mufflers. Tuff Stuff Alternators.
Remember, no matter where you go,
There you are.
Gary
96blazr is offline   Reply With Quote
Old 10-05-2010, 03:12 PM   #12
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
If you click on my build thread, I lowered my front by cutting the coils.Look at the pics, they will pretty much tell you what needs to be done. For the rear people have used jeep wrangler springs for about a 4'' drop.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 10-05-2010, 03:32 PM   #13
scrapmetalart
Junior Member
plan on replacing the lower balljoints while youre at it. it will be difficult to get it apart without damaging the boot on the balljoint anyhow....
-jack the frontend up & put her on secure jack stands.
-remove the wheel (lay it under the truck frame for added protection if something happens to your jackstands...)
-put the floor jack under the lower control arm
-remove the cotter pin on lower balljoint
-loosen the balljoint nut. (just loosen about half way. do not remove)
-give the spindle a whack with a hammer (sometimes this is all that is needed for the balljoint taper to come free)
-if that didn't do it use a pickle fork between the spindle & the lower arm at the balljoint(thats when the balljoint boot gets trashed)
-take the nut off the balljoint all the way
-slowly lower the jack under the lower control arm
-remove spring
-cut the spring (cut off wheel on a 4" grinder works good)(cut 1 coil to start)
-replace the lower balljoint
-inspect the lower control arm bushings & replace if needed
-put spring back in
-jack up the lower control arm
-install nut & cotter pin on new balljoint
-install wheel
-go to the other side & repeat
-use the piece you cut off the first spring as a gauge for the cut on the second spring...
frontstreetcycle on Instagram
scrapmetalart is offline   Reply With Quote
Old 10-05-2010, 03:59 PM   #14
low&slow
Danny Bost- I"m thinking as of now to just stick with the original chassis to get more experience.
1LoC10- Not to be rude, but you should try reading correctly before posting. I was asking how to cut them evenly. I'm young, I can cut anything apart.
71swb4x4- Thanks for the info. I was also wondering about the rear. I do have a totally different plan for the rear.
ChevLoRay- Yes I did know that about Nascar. Thankfully I do have coils so someday I can tweak for Nascar look.
96blazr- Thanks for the website. Those are cheap and may look into taking that path if cutting them doesn't work. Looking to learn new things and gain experience instead of taking the easy way.
usmcchevy- Thanks. This will help me a lot on how I will do mine. Your truck is looking great. Keep up the good work.
scrapmetalart- That helps a ton. Going to have to print that off so I have my instructions with me. Thanks for your time in typing all that up.
Old 10-05-2010, 04:34 PM   #15
raycow
Well the problem for you is the long box. To get a 127" WB you will be looking at some fairly big cars, like Cadillacs, Lincolns and Imperials. Most of them will be rather old, too.
Ray
raycow is offline   Reply With Quote
Old 10-05-2010, 04:57 PM   #16
low&slow
So speaking hypothetically, to make a camaro fit (knowing it won't cause its a unibody) you have to lengthen it quite a bit.
Old 10-05-2010, 05:06 PM   #17
scrapmetalart
Junior Member
You "could" use the front subframe from a camaro & cut the front of the truck frame off & weld the camaro subframe on.
Way too much work. just upgrade & replace your stock components...
Old 10-05-2010, 05:36 PM   #18
low&slow
Yes I do see the work it requires in having the sub frame cut and welded on. A member did that to his using a newer camaro front. I'm not there yet to do that much work, so yes I'm to the point now of just cutting the coils and leaving it at that till I can get some money. It is not a daily driver. In fact its never been driven farther than 3 miles, but has done miles worth of burnouts on the back patio.
Old 10-05-2010, 05:37 PM   #19
1LoC10
Insert Title Here
1LoC10's Avatar
there is a guy that has a 60-66 body style that put his truck on an s10 frame...even kept the 2.2 four banger and all
BOBBY
_69 SWB_
Old 10-05-2010, 05:44 PM   #20
low&slow
I've heard of a lot of people going the s10 route. To me the s10 frame just seems way to small for one of these trucks.
Old 10-06-2010, 02:28 PM   #21
55chevy
Car Truck Bike Nut
55chevy's Avatar
Be very careful when you remove the springs, I havn't done it but if you dont use a spring compressor I've heard the spring can fly out of the truck and shorten your suspension, or your life.
Snow free Florida panhandle, don't miss Indiana winters
Temp in Suffolk Virginia, Sentenced 2 to 5 years LOL
68 shortfleet project
94 3500 TD dually
so many cars so little time
72 K2 CST 2WD Blazer
55chevy is offline   Reply With Quote
