Old 10-05-2010, 02:14 PM   #1
fsjeep
Can I use different coil springs to lower my front?
I have a 94 ext cab 2wd & want to lower the front about 2". I'm a newbie to spring ratings etc.. but I've been looking at the Moog Catalog curious if I could get a different "stock" spring to fit my truck and lower it. Below are a few I have found. CC650 & CC648 are stock recommendations for my truck. I narrowed down the same end types and Inside diameter then 2"-ish lower Install ht at a similar load and got 5044 & 578. First thing I notice is the spring rate is dramatically lower. Am I correct that the spring rate is X lbs to press the spring 1 inch? If so will these springs with a 350 lb spring rating be too soft and bouncy even at the same load rating? Would it be better to look for a 600-700 spring rate?
Model__Insideĝ___Barĝ_____Install ht____Load_____spring rate___free ht
CC650__4.08_____0.906_____12.75_____2325_____1025________15
CC648__4.056____0.875_____12.75_____2300_____870_________15.25
5044___4.08_____0.687_____11________2360_____334_________18.06
578____4.08_____0.703_____11________2325_____358_________17.5
Any ideas/suggestions?
fsjeep is offline   Reply With Quote
Old 10-06-2010, 02:13 AM   #2
OARNGESI
OARNGESI's Avatar
Re: Can I use different coil springs to lower my front?
Have you thought about just a drop spring
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 10-06-2010, 08:43 AM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
Good research and all, but seems like your money could be put to better use. If it were me I would either cut one coil off the stock spring or replace it with an aftermarket lowering spring.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 10-06-2010, 08:53 AM   #4
cdowns
cdowns's Avatar
best thing you can do is buy springs that have been designed and engineered for your specific application by a professional// cuts down on cost with a trial and error type selection
Old 10-06-2010, 09:09 AM   #5
scooterskoolkustoms
scooterskoolkustoms's Avatar
drop front springs at summit are $97.00
big old burb in primer.lot of work to do.
scooterskoolkustoms is offline   Reply With Quote
Old 10-06-2010, 11:48 AM   #6
fsjeep
My thought was I could pull stock springs off another vehicle, not necessarily buy new. Also I want to learn about springs in the process, even if I just go buy drop springs.
Old 10-07-2010, 09:41 AM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
Nothing wrong with research and free thinking. I support that 100%. From experience I can tell you that used springs are going to have sagged a bit, and there is no way of knowing how much till they are installed. Getting them off at a salvage yard has the potential to be a lesson in frustration as well.
Don't be afraid to cut a coil off your existing springs and see how it sets. As long as you don't use excessive heat, this will work just fine. When money permits you may want to go for dropped springs, or maybe keep the cut springs and buy spindles instead.
Articles-
"Refining Sierra"
