'66 wiper issue
does anyone have a wiring diagram for a '66 panel, would even settle for a pu one. My motor has 5 wires going to it and as far as I can tell none of them is hot. I would be happy if I could even make them run with a toggle switch. Any help would be appreciated as aggravated as I am now I am about ready to run a string out the window. $40 for a switch and $160 for a motor is more than I am ready to spend till I can atleast understand why it does not work now. Thanks
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Re: '66 wiper issue
I dont have a diagram handy but maybe I can guide you.
Hot wire from fuse goes to motor ( I think it is yellow), light blue wire goes to switch. BTW do you have a two speed switch? OK, I found one http://webhosting.web.com/imagelib/s...%20w/%20Gauges
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! Last edited by Clyde65; 10-05-2010 at 02:25 PM. |
Re: '66 wiper issue
I have a red wire going to fuse block, a jumper wirer going to two terminalals on the motor and a black and yellow and a black going into the harness
Re: '66 wiper issue
yes it is a two speed switch with a washer bouton in the center
Re: '66 wiper issue
The harness is a new " painless wiring" harness. Had no trouble at all with wipers before changing harness
Re: '66 wiper issue
I am trying to remember mine......I believe the black and yellow go to the pump, the black through the harness should go to the switch. Have you called Painless? which harness did you get?
Looking at their 63-66 wiring harness diagram, page 27 figure 7.19 and table 7.4, does that help you any? I got it off their website
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! Last edited by Clyde65; 10-05-2010 at 02:51 PM. |
Re: '66 wiper issue
They said as long as it was hooked up like the pic provided it "should" work. I guess we are down to part swaping
Re: '66 wiper issue
so you have it like they have stated right? maybe a dumb question but where is your switch? is it dangling under the dash? it needs to be grounded in the dash surround I think.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! Last edited by Clyde65; 10-05-2010 at 02:53 PM. |
Re: '66 wiper issue
everything is mounted like factoty, I did manage to get a single speed with a toggle , no park, no wash, will try a new switch next week I do have confidenece in harrness now. stranger things have happened than a part going bad on the shelf fo a few years, thanks for your help, your wiring diagram seam to be for a single speed motor though
Re: '66 wiper issue
yes your right, single speed. If you need anything else, PM me and I will look at my truck at home...might be with me at the office latter this week though.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
Re: '66 wiper issue
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
