10-05-2010, 02:38 PM | #1 |
Tranny Crossmembers 4wd or 2wd
Call me lazy or whatever you want. I searched a few posts that looked like they would have the info and did not. It may be a stupid question but...
Can I use a 4wd crossmember on my 65 when I convert to an auto or does the crossmember need to come from a 2wd truck? Sorry if this is covered somewhere else but I tried to search.
This statement was made possible by a grant from this station and continued support from viewers like you. Flickr |
10-05-2010, 04:17 PM | #2 |
Re: Tranny Crossmembers 4wd or 2wd
which crossmember are you talking about
ron |
10-05-2010, 04:35 PM | #3 |
What do you mean? Automatic tranny crossmember? I am hoping for one for a TH350, are there that many different ones?
10-05-2010, 05:01 PM | #4 |
I was asking you by what you meant by cross members,"Can I use a 4wd crossmember on my 65". they didn't use an a/t in a 4x4 until 68 or 69 I believe.
they did use an a/t crossmembers for both the p/glide and the th400 which use can use or adapt something else in this should be an informative link for you, http://www.persh.org/pickup/IdeaPage.htm ron |
10-05-2010, 05:14 PM | #5 |
Ooh, sorry thought I put the years, I am looking at a 73-87 crossmember and it is a 4wd one.
10-06-2010, 12:20 AM | #6 |
60-66 Nut
A 4wd crossmember actually supports the transfer case adapter, which I believe is lower than the typical 2wd trans mount. Plus the holes for the mounts are completely different than a 2wd transmission mount. I have not tried to use one, so I'm not speaking from experience in that respect. I would suggest just looking for a '66-'87 2wd automatic transmission crossmember.
10-06-2010, 06:45 AM | #7 |
There is the answer I was looking for. I thought there was a difference but could not be sure. Thanks again Captainfab
