Old 10-06-2010, 09:34 AM   #1
dcmulisha
dcmulisha's Avatar
66 12 bolt rearend question
Sorry if this has been answered somewhere but I could not find it. Can someone tell me what all year models came with a 12 bolt/6 lug rear end that will bolt directly to a 66?
dcmulisha is offline   Reply With Quote
Old 10-06-2010, 11:34 AM   #2
CVA59
Re: 66 12 bolt rearend question
Hope this is of some help. If it's a rear coil truck, 71-72 5-lug housings are a direct swap. 67-70 6-lug housings are 1.5" narrower than 71-72 housings.
Try this link: http://67-72chevytrucks.com/vboard/s...=rear+end+swap
Zack
www.23t.weebly.com
_________________________________
CVA59 is offline   Reply With Quote
Old 10-06-2010, 12:01 PM   #3
jchav62
1962 C-10
jchav62's Avatar
63-70...
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 10-06-2010, 12:13 PM   #4
dcmulisha
dcmulisha's Avatar
Thanks!!! Hopefully this will prove the most easy/cost effective solution to my current highway issue. Another words I'm currently tached out when cruising at 55mph. Now I won't end up with something that will not fit.
Old 10-06-2010, 05:27 PM   #5
raycow
63-64 housings have the panhard bar mount on the RH axle tube. You can use one of these with an aftermarket bar or fab a longer bar yourself. If you want to use a stock 63-64 bar you will need the 63-64 frame bracket too
Ray
raycow is offline   Reply With Quote
Old 10-06-2010, 09:57 PM   #6
brawley
Easy Does It
brawley's Avatar
sorry to but in , but are the 63-64 panhard frame brackets diffrent from the 65-66? if so what is the diffrence? thanks
brawley is offline   Reply With Quote
Old 10-07-2010, 12:20 AM   #7
Captainfab
60-66 Nut
I believe the '63-'64 bracket is pretty much at 90 degrees to the fame. The '65-'72's are at a bit of an angle with the shorter panhard bar that mounts to the upper right of the center section.
And to the OP...thetruck 12 bolts were used from '63-'82. The '65-early '70 will be a direct fit to your '66 retaining the 6 hole wheel pattern.
