Old 10-06-2010, 03:49 PM   #1
WestWardWinds
Frame to bed bushing kit??
I can find cab bushings but i cant seem to find any bushing for a the bed to frame. Anyone know where I can find them??
WestWardWinds is offline   Reply With Quote
Old 10-06-2010, 04:12 PM   #2
scrapmetalart
Junior Member
Re: Frame to bed bushing kit??
the bed bolts solid to the frame
frontstreetcycle on Instagram
scrapmetalart is offline   Reply With Quote
Old 10-06-2010, 06:24 PM   #3
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Don't think we want anything to cushion the bed. A load would ultimately cause them to fail and the bed would end up with a lean and be uneven on the chassis. I'm glad the designers and engineers didn't put cushions on them.
Member Nr. 2770
Old 10-06-2010, 06:50 PM   #4
dfwright
dfwright's Avatar
My truck came with nothing between the bed and frame, and I'll put it back that way, but they do sell pads for this:
Bed Mounting Pads - Shortbed
Bed Mounting Pads - Longbed
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 10-06-2010, 10:39 PM   #5
Zoomin
Man of Mini-Talents
Zoomin's Avatar
I cut up squares from an inner tube and used them between the two.
Zoomin is offline   Reply With Quote
Old 10-07-2010, 09:52 AM   #6
WestWardWinds
Thanks guys I appreciate it as always.
Old 10-07-2010, 06:49 PM   #7
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
I bought a set of pads for my bed from classic parts, there where none there before but as I'd seen them in the brochure I thought they would be a good thing and may stop squeaking between the frame & bed...they are about 1/4" thick and all I succeeded in doing was raise my bed and put the trim outa line with the cab.
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline   Reply With Quote
Old 10-07-2010, 07:00 PM   #8
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Add a 1/4" shim under your cab and rad support bushings. Or just remove the bed mount pads.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 10-07-2010, 07:33 PM   #9
eightbanger
454 MAKES IT ROAR
I like the idea of the bed being cushioned so I reckon on raising the cab as you suggest Diesel.
Nigel.
No more pain.
Old 10-07-2010, 08:19 PM   #10
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
A piece of bicycle inner tube make sense. Otherwise, the out-of-alignment issue makes me think of trying to get a chair level by cutting off one leg, then another, Y3.
Member Nr. 2770
Old 10-07-2010, 11:39 PM   #11
swamp rat
swamp rat's Avatar
I have the bed pads in my truck cab mount kit as well, i have the bed off right now but was going to try to use them and see how it lines up, if not they will ether come out or the cab mounts will be raised to match.
My question will be how tight to tighten the cab mounts? i have slight compression right now.
The other is where to you guys get your spacers?
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 10-08-2010, 12:52 AM   #12
Baged72
Baged72's Avatar
Nothing goes under the bed??
I pulled my bed off to paint it and in the rear it had 2 hockey puck looking things with a few shims.... My bed sat perfectly with these installed.
72 GMC SB
Built 400 SBC
B&M TH350
12Bolt Posi 4:11
Bagged
Baged72 is offline   Reply With Quote
Old 10-08-2010, 11:21 PM   #13
chipflyer
chipflyer's Avatar
When I replaced the wood in my LWB there was nothing between the frame and bed. I replaced the wood and put it back with nothing between the frame and bed and everything lined up perfectly.
Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen.
1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets!
1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241.
chipflyer is offline   Reply With Quote
Old 10-08-2010, 11:25 PM   #14
Sillyoldman
#16876
Sillyoldman's Avatar
I've never used them either???
Posted via Stationary Device
'71 Custom Deluxe C-20 402.
'67 Buick Special 455.
'49 Plymouth Special Deluxe.
"I love that old car smell"
Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
Sillyoldman is offline   Reply With Quote
