Another V8 question
I have a '72 flatbed C30 w/ an overhauled 402BB & 4sp trans.
I get about 7mpg. It's all original including the rear end. I want to put a 283 or even a 6cyl in to improve the milage. The guys I talk to tell me it will be way underpowered and I won't improve the milage. But I see C30's for sale that have 6's in them from the factory. Who's correct? Do any of you have C30's w/ 6's in them? How are they pulling loads?
A man's thoughts devise his ways; but it's GOD that directs his steps. |
Re: Another V8 question
I would imagine if you put a 6 cylinder in there that motor would have to work harder then the V8 so you wouldn't gain anything. If anything you should put a beefier motor so it doesn't have to work as hard.
#3 | |
Drive train efficiency determines fuel mileage not engine displacement. Everything - carb tuning, to gear ratios, to tire diameter.
1969 c-10 Step Side Long Bed. I-6 250cid = ![]() |
its all about the +6 inches
You need to figure what gearing you have.
Off the top of my head, I can't remember if that would be a 4.10 or a 4.56 gear. if it is a dual rear wheel truck, it's a 5.13. I would seriously consider getting a later model 14 bolt rear with a 3.73 or so gear ratio. The engine can pull plenty. And most likely, you aren't even hauling/pulling the major weight the truck was built for anyways. A smaller engine would help, but not as much as better gearing. Regardless of the engine, you'll still be reving 3000+ RPMs on the road, and still getting passed by socker moms left and right. |
#5 | |
RAT1968 '68 Cab/'71 Parts
On a good day, I got nine. But it could climb mountains.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
