TH 350 problem...Need some advice guys
1985 c-10 305/350 combo
I am trying to pull this truck outta the woods because it was free, and it has a trans issue. Previous owner (10 years ago) said that it had a head gasket issue. Well low and behold it really doesn't. It holds all the coolant and doesn't smoke(after running for 2 1/2 hours) Bigger problem it has is this with the trans. It basically is puking trans fluid out as fast as it is going in. what fluid that was still in the trans did n not smell burned and is not really discolored other than normal color. I cant see anywhere externally (lines, pan, modulator, rear seal). am I safe to assume that the only other place that it might be leaking out of is the front seal? When you fire the truck up and put it in gear it tries to move itself forward(Can feel it try to move itself slightly) but loses the fluid almost as fast as you're putting it in. Does anyone think this may be worth trying to put a front seal into the trans to see if it might work or am I barking up the wrong tree here and should just replace it. since it feels like it is trying to move before it loses all the fluid I was just hoping since the seal may be shot that it just cant build enough pressure to move. Just curious everyones thoughts. Thanks in advance Gregg
Just would like the snow to stop so I can actually work on my truck!!!!!!!!!!! |
| Bookmarks |
