Old 10-06-2010, 10:58 PM   #1
darrylhopkins
Front Upper Shock Brackets
I was wondering if anyone has used CPP Part #6072 FUSB and had any good pictures of the installation. My truck is a 1970 2WD Longbed and the passenger side had about a half dollar size hole where the previous owner liberally used washers and a bearing of some kind in an effort to repair it, so I don't think the reinforcing kit will do here. The front end including K Member is from a 71 C-10 and is rebuilt, and I have a stroker motor with a deep pan so spings spindles and all are stock height. They post the installation instructions for a lot of their products on their site, but I didn't see one for this product, so I am wondering if it uses stock shocks or do they need to be longer since the shock mount is a little higher(On top of the frame as I understand it) and how do you ensure you are mounting it at the correct point so your shocks don't bind. Ay help would be appreciated.
darrylhopkins is offline   Reply With Quote
