87 GMC heater problems
Does anyone have or know where I could find a diagram of the vacuum layout for the heat / AC system in my truck. I know I have a vacuum leak I can hear it but I cant seem to find it.
Truck is a 1987 GMC 3500 with AC. Any help or direction would be appreciated |
Re: 87 GMC heater problems
You can spray carb cleaner around the vac. lines until the idle changes. When the idle changes you just found where you leak is.
78K & 79C Jimmys
don't think i got a diagram but this is one spot to check out
It is a pop spot for a leak where do you here the leak in the cab ,which side ,under/around the controls?
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
The leak (whistle) is coming from the dash deep in the center behind the heater controls.
Also I know there is a leak or a problem because the defrost vents will not work. I have the dash pad off and I will be looking into it real serious this weekend, just figured if there was a diagram available it would be a start...........no big deal I will just start hunting through till I see something that doesnt look right. I will check that selector first though easy enough to get to. Thanks |
