10-07-2010, 11:53 PM | #1 |
Winter Project
So what plans do you have for the winter I'm gonna pull the engine and trans to detail engine bay, remove the bed so I can notch the rear rails, swap the torsion bars with 78 clip and bags all around should keep me busy for a while couple more porjects but can't give everything away
10-08-2010, 12:18 AM | #2 |
Re: Winter Project
Im going to build a full frame for my 53' Dodge and hopefully chop, body work, paint and do interior if time permits....Basically Re-do it....There never done are they?
Justin
[PROJECT] FnLow69- 69 C-10 Full frame & layin' doors [PROJECT] Laidout53 - 53' Dodge Pickup, Full Kustom Build [PROJECT] "Hot Rod" 1931 Model A Bonneville style "Dream as if you'll live forever, Live as if you'll die today" ~ James Dean |
10-08-2010, 01:08 AM | #3 |
What was I thinking?
Re: Winter Project
I plan to do a lot of after hour jobs. Have to refuel my savings. So I can work on my projects. Good luck with y'alls!
Justin '68 C/10 Custom Long wide bed '78 GMC Sierra short wide Project: Second time around...'68 short wide http://67-72chevytrucks.com/vboard/s...d.php?t=423949 |
10-08-2010, 01:56 AM | #4 |
Re: Winter Project
Pull the motor and trans on the '67 and build a strong motor to handle twin turbos backed by a T5!!
10-08-2010, 02:15 AM | #5 |
Re: Winter Project
have the body mods an body work done an the truck in primer an build the frame and put it back under the truck..
