Steering coupler (Rag Joint) size
Does anyone know what size Rag Joint for a 1985 K10 power steering 4wd?
![]() Join Date: Dec 2008
Re: Steering coupler (Rag Joint) size
dont know if this helps http://www.jegs.com/p/Borgeson/Borge...55269/10002/-1
good luck |
![]() Join Date: May 2009
Get rid of it and put in an XJ shaft.
03 GMC Yukon XL 2500 Quadrasteer, wife`s DD 84 Chevy K30 CC SRW 55 Chevy 210 2dr post |
can you include details about that swap? thanks
Greg 1974 GMC 1/2 Ton SWB Fleetside L33 5.3/4l65e .................__
............._____l __\__ ..............l_(O)_ l___(O)] |
Pretty much a bolt in, like $20 for a junkyard shaft. You need to make a slight notch at the steering col end for the bolt. You also need to compress the shaft slightly to install. If you google it you can most likely find more info. I did mine in under an hour, outside in the winter, very popular with the 4WD guys.
what are the benefits to the swap?
It Is What It Is,,,,
*79 C10 Short Box ST8 6 bang'r * *Lowered w/ 3" Control arms, 2" Lower Coils and 4" shackles and hangers W/ FLIP KIT *__--__* 79 C-10 project* .........................__ ..............._____ l __\___ ..............|_(O)_ |___(O) ] FAQ INDEX Thread The Kulture My Rat Den
It gets rid of the sloppy rag joint. If you click the link you can see the XJ shaft, solid couplers at each end. That thread is very informative, but a bit overcomplicated. You get a little more road feel transmitted through the solid shaft, but I have been happy with mine, plus it is a cheap and easy mod.
![]() Join Date: Feb 2010
Weymouth, Ma? I'm from Cohasset!
Cool, nice down there.
Wonder if this could be used for a manual steer box?
I would think so, as long as the ends are the same size as the p/s set up.
| Bookmarks |
