Old 10-08-2010, 09:28 AM   #1
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Ordered disc disc prop. valve and it has 5 ports...?
2 ports on the top for the MC lines
1 port on the back going to the rear brakes
1 port on the bottom front going to the front brakes
1 port on front going up at an angle, where does this go? (its right above the button)..
thanks
John
1999 Toyota Tacoma 4x4
Old 10-08-2010, 10:00 AM   #2
Shane
Shane's Avatar
Re: Ordered disc disc prop. valve and it has 5 ports...?
plug it ...
Shane is offline   Reply With Quote
Old 10-08-2010, 10:10 AM   #3
oldblue1968chevy
ok..
what does it go too (if imma plug a port, id rather plug a port on the bottom or somewhere out of sight...)
thanks
John
Old 10-08-2010, 12:45 PM   #4
way2lo2
way2lo2
way2lo2's Avatar
Originally Posted by oldblue1968chevy View Post
ok..
thanks
its there so you can run one to each front wheel. We typically tee the front wheels together and plug that port. I've been getting away from using the combination valves lately and have been using the adjustable proportioning valves for better tuning.
way2lo2 is offline   Reply With Quote
Old 10-08-2010, 02:32 PM   #5
oldblue1968chevy
yea the fronts are T'd togeter at the crossmember..
(only 2 lines comming up to prop. valve, 1 for the rears and 1 for the fronts...
also i wanna paint my mc but it nees to be baked @ 200* F i took snap ring out but there is stillome kind of rubber/plunger in there..hwo does it come out?
John
