assembly line hand written markings
any one know what type marker was used on the assembly line to mark firewall etc. my 64 has a large handwritten 2 on firewall that i want to duplicate after painting
Re: assembly line hand written markings
Yes - they were a large crayon, like they use in the tire stores.
Some restoration shops/catalogs sell them as well. Any color could be used (whatever was handy - white, yellow, red), and it could vary based on plant, shift and/or operator, so I would recommend you simply document how it looks now and try to duplicate that. K My truck was number "87": ![]() ![]() ![]()
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 10-08-2010 at 01:08 PM. |
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
Thank you very much for the info and pics, Keith..............do you know what these numbers signify
You are welcome.
In my case it was the "build sequence number", so it was just the number of the vehicle as it came down the line. It is the last two digits of the "manifest sequence number" and they increment up in order. The truck after mine would be 88, then 89, etc. Once they got to 1000 they would usually start over at 1, 2, 3 etc. Not sure what just a "2" might mean; could be the same thing, or could be a flag for a specific option code, or second shift, or someone's lunch menu choice.... (I'm serious). If you find a "2" in some other locations, like under the hood, on the diff, on a tire or wheel, then that would lend some credibility to it being your build sequence number. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 10-08-2010 at 09:50 PM. |
