Old 10-08-2010, 03:15 PM   #1
57 Jimmy
57 GMC- What 4sp would work?
Hi guys this is my 1st post I know no intro. I've lurked here awhile.
Anyway does anyone know if theres a direct swap to my stock 347 Poncho? say a late model or just any 4speed other than another creeper type truck trans.
Thanks for any help or tips.
57 Jimmy is offline   Reply With Quote
Old 10-09-2010, 05:41 AM   #2
raycow
Re: 57 GMC- What 4sp would work?
If you have a bellhousing on the engine now, you can bolt up any common GM 3 or 4 speed car transmission or a T-5 from a Camaro or S-10. You can also use an aftermarket transmission like a TKO or Richmond. If you don't have a bellhousing, you will need to find one from a 55-59 GMC truck. A Pontiac car bellhousing will NOT have the mounts you need.
Ray
raycow is offline   Reply With Quote
Old 10-09-2010, 09:51 AM   #3
57 Jimmy
Raycow thats great. Do you know if the input splines are the same and or have to be lengthened or shortened or is this a direct bolt on ? Yes I have the orginal bellhousing the truck is driven as we speak, I just want to up grade or have a plan B if you know what I mean.
Thanks for your help.
Old 10-09-2010, 02:11 PM   #4
raycow
If your replacement transmission has a 10 spline input shaft, everything inside the bellhousing stays the same. If it has a 26 spline input, you will have to change the clutch disc and that is all. The S-10 requires shortening the input shaft and bearing retainer as well as replacing the disc.
Ray
Old 10-09-2010, 03:06 PM   #5
57 Jimmy
Thanks your knowlege is very valued, hope this helps someone else also.
Again thank you!
