First time owner with some questions.
Hello everyone. I just picked up a 74 Shortbed C/20 350/350. The block is brand new essentially from mid line up (the bottom has yet to be rebuilt).
I've got some questions though. This is my first truck. I'm used to working on Z/28s, and other sports cars. I'm not used to some of these things on the truck, and I have yet to get one in this condition. Rust is an issue, especially along the doors, just next to the bench seating on either side. So I've got a list of questions, and if anyone could provide information, links, personal experience anything I'd be greatly appreciative.
I've got plenty of questions, but I can't bombard everyone at once heh. More information in my signature. I'll get some pics for you guys of some of the troublesome areas. Thanks in advance, I look forward to working on the truck, and having fun in a new community (big z28.com contributor here). Again, thank sin advance, and I apologize if it's too much for one thread >< Cheers!
San Diego, CA Professional Body Modification Technician. '74 Shortbed C/20 350/350 Last edited by Menekali; 10-08-2010 at 05:14 PM. |
Re: First time owner with some questions.
well hello and welcome aboard from new jersey.
unfortunatley, i cant be much help to you. i dont know much about much, so i come here and ask questions. good luck with your truck. im sure soon enuff you will be getting a bunch of replies to each and every question you have posted. great bunch of guys here with tons of knowledge. post pics. always helpful and everyone wants to see another square!!! |
#3 | |
![]() Here are some support pictures. More to come ![]()
San Diego, CA Professional Body Modification Technician. '74 Shortbed C/20 350/350 |
More pictures to help the advice along
![]() Also as far as anyone can see with the body, I can fix most of the obvious dents and dings with bondo correct? Should I be going for something like Rage Extreme (http://www.evercoat.com/productDetail.aspx?pID=146) or would something like a Bondo Quick Fix be sufficient (http://cgi.ebay.com/ebaymotors/BONDO...motiveQ5fTools). Again, sorry for the barrage of questions! I've got a lot I know heh.
San Diego, CA Professional Body Modification Technician. '74 Shortbed C/20 350/350 Last edited by Menekali; 10-08-2010 at 10:34 PM. |
![]() Join Date: Dec 2008
welcome aboard from ALA
Exhaust 3.5" Straight pipes to big 2 1/2 as big as i would go on a street setup. interior and bench seat http://67-72chevytrucks.com/vboard/s...d.php?t=420500 RUST http://www.youtube.com/results?searc...made+easy&aq=7 chrome bumpers Over time, chrome oxidizes and develops rust spots. The higher quality the chrome plating, the more it will resist rusting, but eventually, it will happen. If you allow chrome to go too long without removing rust, it will become permanently pitted. so some chrome polishe will help you here The doors http://www.youtube.com/results?searc...ruck+door&aq=f flat black if it was me i would go with hot rod flatz but if your going for a primer look be sure to use some type of epoxy because regular primer is not uv protectant and will turn white and chalky eventually hope this has helped somewhat oh yeah the gas tank id get that looked into right away by a pro Last edited by nbpro; 10-09-2010 at 11:49 AM. |
i wouldnt go over a fourth of an inch in the bondo repair tends to crack if you do
http://www.evercoat.com/productDetail.aspx?pID=32 should be all you need and was advised by a bodyshop owner here in the forum Last edited by nbpro; 10-09-2010 at 11:41 AM. |
Rust looks very typical of a SoCal beach truck. Salt air laying on the body for long periods of time rots them from the top down (you should seen my neighbor's '65 C10). I'd guess that bad weather stripping (dried out from our socal heat) and maybe a blown heater core has caused the internal rust. Water has run into the cab corners and sat until it rotted. Probably under the damp floor mats or carpet.
Pre '75 you don't need a cat on the truck in CA. No smog check. The truck is worth the effort on that alone. I'd probably replace the cab rather than mess with the rust repair. But Classic Industries up in HB has a lot of body stuff for your truck and it's relatively inexpensive. Especially compared to your Camaro stuff. I'd probably just pick up a cheap set of turbo mufflers and replace the glass packs. Probably all in for under $50. Oh yah, gas tank... My bet would be you've got a plugged vent. Good luck and enjoy that classic truck! Remember, they're not making any more 1974 Chevys!
'87 R30 Crew Cab Dually It's 11 PM, do you know where your IAC pintle is? Last edited by Hulk Will Smash; 10-09-2010 at 11:56 AM. |
#8 | |
Happy to be here
![]() Join Date: Mar 2000
![]() Quote:
dont know if id go as far as replacing the cab from what i can tell in the pics it can be repaired with some new floor pans and so on now if you already have a new cab its a different story first thing i would do is wire brush everything off to see how bad the cancer is then go from there but the rust i saw is pretty typical for these trucks that havent been maintained i would think about a new hood looks like that one is bent where it rusted
good luck Last edited by nbpro; 10-09-2010 at 01:57 PM. |
