Help! Problem laying bed wood
This afternoon I started laying my newly varnished wood and ran into a problem. Not sure why this is happening and figured someone may have seen this before. The two pieces of wood that have the bolt holes will not lay flush because of the frame rivets shown in the photo. There is a very small space between the wood and the frame cross member. Maybe 1/8". The head of the rivet is taking up that space so the board will not lay flat. I imagine I could put spacers between the frame and sills to raise the bed but I didn't think this was necessary. Has anyone seen this problem??
'68 C-10 SWB 383 Stroker (Sold 3/2/2013) '87 R2500 LWB 454 TBI converted to Carb ![]() Last edited by AusTx68; 10-08-2010 at 04:51 PM. |
Re: Help! Problem laying bed wood
Here's what else I noticed. The bed is obviously sitting low when you look at the bedside line body line compared to the cab body line. Correcting this line would also fix the clearance problem with the rivet. Still I can't figure out why this is happening.
'68 C-10 SWB 383 Stroker (Sold 3/2/2013) '87 R2500 LWB 454 TBI converted to Carb ![]() |
did you put the pads on top of towers?
there are pads that go between the top of towers and the bed supports.....good luck sir |
#4 | |
on a long bed you should have 10 of these pads that go on top otowers between bed and tower
Rat has your problem solved. If that isn't enough to come out flush I would put an additional shim for this to look right.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
or if you dont want to screw with the bed right now you can just make a dip in the wood where the rivet goes??
-diggin the truck and the painted wheel wells though, looks TIGHT!
........................ __ ............._______|__\____ ............|_({})______({})] ................(O)..........(O) Last edited by Youngbuck7072; 10-08-2010 at 11:50 PM. |
Where can I buy those? I couldn't find them in the LMC catalog.
I saw some on Mar K's website
Part Number: 120181 ![]() Last edited by 68CEE10; 10-08-2010 at 10:10 PM. |
and whats up with the battery under the bed??
........................ __ ............._______|__\____ ............|_({})______({})] ................(O)..........(O) |
since those are soft cushions i'd think that wouldn't solve the problem. i'd make spacers out of metal and tack weld to the mounting pads on the frame
dont forget to run a good ground wire from the bed to the frame so your rear lights work properly
Looks like a nice paint job. Pictures of whole truck?
72 Fleet (died) 78 Step (sold) 55 Step named Fred (sold) 00 F150 68 Step (named El Scorcho by PO) Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932 |
#13 | |
I relocated the batter to clean up the engine compartment
Here are pics of the finished bed..actually 95% finished. Still need to tighten all the bolts. The pics of the whole truck are when it came home from the body shop. I have since put it together but have been waiting to finish the bed before taking more pics. My interior is currently at the trim shop. Should be ready by middle of next week. I can't wait!! ![]() ![]() ![]() ![]() ![]() ![]()
#14 |
that truck is BAF. Where did you get the clear tail light lenses?
#15 |
![]() Join Date: Jul 2005
Beautiful job. too sweet to drive. I left mine just a little bit trashy. very nice appearance in the bed wood. Great job congradulations. J.W.D
Larry
The biggest problem people have, is other people Thou shalt be cool and not hassle ![]() Be a site supporter. ![]() The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2 |
#16 |
What was I thinking?
Truck looks GOOD! I love that color!
Justin '68 C/10 Custom Long wide bed '78 GMC Sierra short wide Project: Second time around...'68 short wide http://67-72chevytrucks.com/vboard/s...d.php?t=423949 |
#17 |
Very nice job on the truck, excellent
Mark 67 c20 custom camper 55 Olds 2dr hardtop 96 mustang 11 dodge nitro |
#18 | |
http://cgi.ebay.com/ebaymotors/1967-...#ht_1156wt_939
#19 |
Love the color!!
Brad handshoe |
#20 |
Dude, your wood bed looks sweet! can't wait to see the truck in person!
