Old 10-08-2010, 05:30 PM   #1
packrat42
packrat42's Avatar
88-98 Bench seat in our trucks????
Just wondering if anyone has a 88-98 bench seat in our trucks. If so any pictures/ info on what to make it work. Thanks
'72 Nova
'71 C10
'63 VW Beetle
...............................____
.................________-|___\____
..;.;;.:;:;.,;.|__(O)___|____/_(O)|
_______________________________________
packrat42 is offline   Reply With Quote
Old 10-08-2010, 05:52 PM   #2
scrapmetalart
Junior Member
Re: 88-98 Bench seat in our trucks????
I believe thats whats in my truck. The front bolt holes lined up & bolted it in. i was too lazy to bolt the rear in...
frontstreetcycle on Instagram
scrapmetalart is offline   Reply With Quote
Old 10-08-2010, 07:54 PM   #3
Beuford
Beuford's Avatar
I have `97s in mine. The wife and I love it with the air adjustable lumbar. You'll have to drill 4 holes. I got the shoulder harness and seat belts to match with mine. Don't forget the wireing harness when you get them.
Beuford is offline   Reply With Quote
Old 10-08-2010, 08:04 PM   #4
bigguy69
dazed and confused
bigguy69's Avatar
i have a 90 chevy in mine. i like it lot better than the factory seat. i used the back bolt holes in mine . if i can find a camera i wil get some pics
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 10-08-2010, 08:22 PM   #5
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
I put one out of an 89-90 vintage in my '68 and one from a '96 in my SWB. Here are some pics (The '96 seat has been re-shaped considerably but it gives yo an idea of the "fit").
I used the front holes and build an "adapter" plate that I attached to the back of the seat frame and uses the rear factory holes (You can just see it behind the seat belt). I found this to be the most comfortable and provides the best fit in the cab. By leaning the seat back a bit it puts the top of the seat back flush with the bottom of the rear window.
1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD)
1978 Chevy C/10 SWB
1970 Pontiac Lemans
C10-Driver is offline   Reply With Quote
Old 10-08-2010, 08:49 PM   #6
Sammy
Nice interior! Everything flows real smooth. You do the custom door panels?
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 03-01-2020, 05:19 PM   #7
RedRider
RedRider's Avatar
Bump for an old thread here...
I really like these 88-92 bench seats, especially the ones with the driver's armrest. I'd like to find one to reupholster in the 67-72 original cloth or vinyl style (or as close a possible).
Anyone tried this or have experience doing so? Any feedback would be appreciated before I start looking for one.
Example for reference:
1970 C-10 "Old Yeller"
RedRider is offline   Reply With Quote
Old 03-02-2020, 07:32 AM   #8
Bigdav160
Bigdav160's Avatar
IIRC, that fabric is bonded to the foam. No idea how you would recover them.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 03-02-2020, 08:02 AM   #9
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: 88-98 Bench seat in our trucks????
I have one in the Ramp truck now. I had one for about 10 years in my 71 C-10 it was a 60/40 seat no arm rest but swapped them for 99 Tahoe heated seats. They both have arm rest's in them. I have another one going in the 68 step if I keep it. I used the shoulder belts out of each vehicle also.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 03-02-2020, 10:50 AM   #10
raggedjim
raggedjim's Avatar
Here's one I had recovered. It was expensive, and the guy said NEVER again! It can be done.
Good luck, Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
raggedjim is offline   Reply With Quote
Old 03-02-2020, 02:03 PM   #11
67C10Step
67C10Step's Avatar
Here's another one. This was the only modification to my truck when I got it other than an FM radio adapter and speaker. It looked a lot like the one in RedRider's post but I took the superclean and pressure washer to it. Figured I didn't have much to loose and it cleaned up pretty darn good.
Uses the back two factory holes and the installer drilled two new holes up front.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 03-02-2020, 02:53 PM   #12
robpp
robpp's Avatar
anyone shorten the bases? of these 88-98
im installing a tilt column but still want more room.
I look out the top of the windshield.
I saw somewhere they used some universal sides brackets but I cant find it now.
Here mine now
robpp is offline   Reply With Quote
Old 03-02-2020, 03:24 PM   #13
RedRider
RedRider's Avatar
This is what I was worried about. To reupholster it in the 67-72 style may not be worth the time and effort.
I appreciate the pics, thank you all for the feedback. I'm looking at a new Glide Engineering frame; they have a fold-down armrest similar to the 88-98 style, although it's more centered in the seat.
Old 03-02-2020, 04:25 PM   #14
kaycee
kaycee's Avatar
Here mine now
Maybe look down in the FAQ part of forum ,I remember someone did it they took out 1" I belive ,wouldn't be hard to do.
These are 99 yukon 60/40
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327
kaycee is offline   Reply With Quote
Old 03-02-2020, 05:57 PM   #15
Andy4639
Old member
Andy4639's Avatar
Question Re: 88-98 Bench seat in our trucks????
You used a pressure washer on that seat!
Old 03-02-2020, 10:23 PM   #16
67C10Step
67C10Step's Avatar
Andy,
Yes I did! Turned the pressure down to minimum, started at the top and worked my way down. It was after soaking down with a 50/50 mix of superclean and water. Repeated the process twice and then sucked as much water as I could out of it with a shop vac. Moved it into the sun and let it dry.
You should have seen the brown water coming out of it! I figured I would not keep the seat so if I ruined it I wasn’t out much.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
Old 03-02-2020, 10:54 PM   #17
Andy4639
Old member
Andy4639's Avatar
Cool Re: 88-98 Bench seat in our trucks????
I just bought one just like it that needs a good cleaning but I don't think my pressure washer is adjustable except for the different heads for it.
Old 03-03-2020, 12:37 AM   #18
72k20Farmtruck
Look up stockinteriors.com
They actually carry all of these factory seat covers (88-94) if you prefer the factory look.
72k20Farmtruck is offline   Reply With Quote
Old 03-03-2020, 10:10 AM   #19
maverickmk
maverickmk's Avatar
I am looking hard for a red bench like the one in your pics.
Die with memories, not dreams.
Not to brag, but I don't need alcohol to make really bad decisions.
1969 GMC Short Step Side
maverickmk is offline   Reply With Quote
Old 03-03-2020, 10:43 AM   #20
337
Can you guys post pics of any adapters you fabricated as well. Would like get ideas on how to use all the bolt holes for these obs seats.
337 is offline   Reply With Quote
Old 03-03-2020, 05:40 PM   #21
71gmcC15
71gmcC15's Avatar
My rear crew cab seat.
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original )
94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless
07 gmc sierra classic rcsb 4.3 lt 5 speed w/t
04 chevy Silverado 1500 ext cab 5.3 4l60e.
81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green)
71gmcC15 is offline   Reply With Quote
Old 03-03-2020, 05:42 PM   #22
71gmcC15
71gmcC15's Avatar
How you install cub holder I have the same cup holder out of my 07 gmc.
Old 03-04-2020, 12:58 AM   #23
kaycee
kaycee's Avatar
TOOK SOME 1 " Flat stock and cut 2 pieces about 8" long and mounted to cup holder then over to the seat frame and attached it with sheet metal screws. So the bracket I made kind of resembles a H
2005 FXDWG stage3
63 IMPALA 327
Old 03-05-2020, 11:18 AM   #24
'70_402
'70_402's Avatar
Love mine... bolted right in... Sits alot lower than the stock seat as well..
'70_402 is offline   Reply With Quote
Old 03-05-2020, 11:38 AM   #25
71gmcC15
71gmcC15's Avatar
Sweet. When I get it out again I'm going to have to do this
