Crossmember swap
I have a few questions on a front crossmember swap,
#1- I have a 69 short step with drums (no power) all the way around, Now I can potentially buy a front crossmember disk-disk with sway bar 5 lug, If I understand the swap right I just unbolt my complete crossmember and bolt the new in? #2- I also can get the rear end (to complete the 5 lug swap) I dont know if the rearend is a posi but the question is could I swap the axles from the 5 lug axle to 6 lug rear end housing? My truck originally has a 12 bolt posi almost forgot the donor truck is a 78 chevy 1/2 ton scottsdale Thanks for the info, Eric
69 chevy stepside (project) ![]() 2006 Silverado Z71 Ext. cab ![]() 2005 Saturn VUE (wifes dd) Last edited by steppside69; 10-08-2010 at 07:03 PM. Reason: frogot important detail |
#2 | |
Re: Crossmember swap
Answered in RED.
While you are at the salvage yard, grab the center link and tie rods too. Your stock rod ends are too small for the spindles.
Ray |
I have been reading the faq section, Not trying to be lazy just found out it was there
69 chevy stepside (project) ![]() 2006 Silverado Z71 Ext. cab ![]() 2005 Saturn VUE (wifes dd) |
