Mounting a 66 c20 cab to 71 c10 frame question
I have a 66 c20 cab I want to mount to a 71 c10 frame and I don't know what kit from LMC to order. Do I order the 66 truck kit because of the cab? Or do I order the 71 kit because of the frame? Has anyone done this, if so what did you do? I don't want to order both and return the other to LMC but if I have to then I have to. I found out that you just can't mount a 66 core support the a 71 frame because the 71 frame nose dips down 3.75" from the top of the frame and the 66 dips 2.5" so before I make a mistake and build my fan shroud incorrectly I guess I better mock up the rusty cab on my powder coated frame first eventhough I'm not ready, thus my question. Any help would be much appreciated. Thank you in advance.
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: Mounting a 66 c20 cab to 71 c10 frame question
You're going to have to change the rear cab mount bracket on the frame. The '67-'72 bracket is a little different than the '63-'66. I think if you change the radiator support bracket, that will help with that part. The front bumper frame horns are different on the '67-'72's as well.
SSN 706
http://67-72chevytrucks.com/vboard/s....php?t=327644;) It's a 73. The guy's into blow up dolls so watch your back.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by daverod; 10-10-2010 at 10:11 AM. |
Body mounts follow the body, you will have to move the rear body mount....that is it. My 65 core support bolted right onto a 69 4x4 frame.
Sold...1965 Chevy 3x4 ton 4x4, short bed step side |
