Old 10-08-2010, 10:14 PM   #1
Tony_SS
Tony_SS's Avatar
Changing Dumbo Mirrors to 89-91 Power Ones
Has anyone done this? Even if the power is not functional, is it a hassle to mount them on a truck that had factory dumbo ones?
Tony_SS is offline   Reply With Quote
Old 10-08-2010, 10:24 PM   #2
Davidmichael
Davidmichael's Avatar
Re: Changing Dumbo Mirrors to 89-91 Power Ones
from what I have read, you have to convert it by mounting the new mirror and then fill in the holes where the dumbo mirror was. Then swap out or modify your inner door panel if you want the controller mounted.
86 Suburban 2WD = rolled it and totaled it
83 LWB STD Cab 4x4 = went to the scrapper. Was my baby.
84 Suburban 2WD = stripped it/ scrapped it
81 8 foot bed made into a trailer
86 Suburban going to be made into a trailer
91 Suburban 4x4 = that's my baby
00 S10 Xtreme STD Cab
01 S10 ZR2
Davidmichael is offline   Reply With Quote
Old 10-08-2010, 10:26 PM   #3
Tony_SS
Tony_SS's Avatar
I'm wondering how they are mounted... that's my main concern. I don't remember how they were on my old Sub.
Old 10-09-2010, 12:06 AM   #4
Manbearpig
Manbearpig's Avatar
Do want to see pics
1972 GMC C10
Manbearpig is offline   Reply With Quote
Old 10-09-2010, 09:16 AM   #5
mullit
mullit's Avatar
let ya know when i get around to doing mine. not gonna do the eletricial just keep em manual. should have to just drill new holes in the door make a backing plate for inside the door skin so the nuts and bolts dont pull through and just weld up the holes in the door from the old mirrors
mullit is offline   Reply With Quote
Old 10-11-2010, 10:35 AM   #6
Jonboy
Slots go on anything!
There is an "S" shaped brace that goes to the bottom bolt also. I think mounting the inner control is just a matter of drilling a couple of holes, and it screws through the back of the panel. The power mirror equipped trucks originally had a unique movable door glass also, that blacked out the backside of the mirror.
1974 Jimmy- 5.3/4L80e/NP241
Old 10-14-2010, 10:59 PM   #7
JEM
Ironmonger
The reinforcement plate inside the door is different and the mounting holes are all different, there's also a brace that snakes around the front window track.
Ideally you need to rob all the mounting hardware off a set of power-mirror doors. Fill the old holes in your door (which may mean tackwelding some sheetmetal behind the holes), drill the new holes, install the backing plate and mirror.
JEM is offline   Reply With Quote
