Old 10-08-2010, 10:41 PM   #1
tantrumpipeline
Master Procrastinator
tantrumpipeline's Avatar
DIY dropmembers and pics?
looking to make my own dropmember I have seen it done a few times, was thinking of using sched 40 4inch pipe with bracing, what are you guys runing, I can't afford CPP or porterbuilt right now butwill do this swap eventually. going 5.5 in the front and 7 in in the rear
My Buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=395506
20 Duramax tow pig
68 2wd short stepper project
77 2wd short fleet beater
52 short project
tantrumpipeline is offline   Reply With Quote
Old 10-09-2010, 12:12 AM   #2
dv8customs
dv8customs's Avatar
Re: DIY dropmembers and pics?
Take a look at how Scott's Hot Rods does there crossmembers. They are made from 2x4x1/4 and would be the easiest style to fab. There is a lot to maintaining proper geometry though so don't just jump into it.
dv8customs is offline   Reply With Quote
Old 10-09-2010, 04:40 AM   #3
tantrumpipeline
makes sense I am a pipeline supervisor though so have some of the best welders in the industry at my disposal all the time, thanks for the info
20 Duramax tow pig
52 short project
Old 10-09-2010, 06:28 PM   #4
PBFAB.COM
PBFAB.COM's Avatar
Thye two main concerns will be the welding/fabricating (which you have covered) and then the suspension/steering geometry.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 10-09-2010, 08:47 PM   #5
tantrumpipeline
that's my biggest issue, may just slam it all together without the dropmember, and put the build back a little if i have to, for the drop I'm running, a mild dropmember is all I'll need, have to shim the rear end and then install the dropmember after I get my grand slam installed now, but that's not so bad
20 Duramax tow pig
52 short project
Old 10-11-2010, 02:51 AM   #6
blazed89
blazed89's Avatar
remember just cause you own a welder doesnt mean you are a fabricator. not trying to be mean but saftey should be the first thing
blazed89 is offline   Reply With Quote
Old 10-11-2010, 11:19 PM   #7
tantrumpipeline
good point for sure, but I was getting at that to some degree they're mostly pipe welders, but I have @ that are into serious rock crawling and do some very impressive fabrication, either way though.....probably go with porterbuilt or cpp as I can afford to do so, there is a reason the 67-72 guys stick to these guys for critical parts, and they're visually appealing that counts to me
20 Duramax tow pig
52 short project
