8 Lug disc conversion
What exactly are the parts required to convert a 72 C30 to power front disc brakes. I have not gone and looked at the truck yet but it appears as though it has split wheels, and im sure it still has drum brakes, altough i can see a dual pot master cylinder and it has a brake booster.
If it does indeed need a conversion, what exact parts are required and what are the relative costs associated. These little things will determine wether or not to buy this truck. I already know it will need wheels and tires, a bed, probably a tune up or so. Its real easy to drop a couple grand in a hurry |
Re: 8 Lug disc conversion
If it doesnt already have discs, just buy a pair of discs off a 3/4 axle. (you can usually get these sort of parts from another board member). my K20 has front discs. having discs or drums on the back(IMHO) doesnt really add noticible stopping power, but its nice to have them on the front
........................ __ ............._______|__\____ ............|_({})______({})] ................(O)..........(O) |
and do you have any pics of the dually/
If you indeed have power drum brakes, you will need spindles, rotors, calipers, brake hose L&R, banjo bolts, the master cylinder, and the proportioning valve. Likely you will need to redo the plumbing a bit too. Except for the plumbing, it really just a bolt on affair.
C10s all when to disc in 1971. C30s might be different.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
Like I said I havent gone to look at it yet, and the pics are quite small, but after having a couple of C10's you kind of get a feel for the problem areas. It could be a total piece of crap though.
![]() ![]() ![]() ![]() It sure would be nice if it does have front discs. I just cant see myself driving this thing every day in atlanta traffic without discs |
that dually looks TIGHT. and what kind of block is that// 383?
Six in a row makes it go...
![]() Join Date: Mar 2009
This one says it only fits 3/4 tons. I'm not sure why that is.
http://www.brotherstrucks.com/prodin...ber=DBC8L20-SS
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
Rollin Coal
for dually trucks the front disc and hub are one piece. they are offset about three inches to allow clearance for the caliper/rim. if memory serves correctly they are the same part number as 73-87 dually two wheel drives-not 100% sure on that.
I have three letters to all these import guys: God-Made-Chevy 04 GMC Sierra 2500HD Duramax ![]() 1972 Chevrolet C-30 Dually Pickup stock? 350 SM465 four speed ![]() 1977 GMC K-35, TH-400, 4X4 450 horse 454(dad's) ![]() 1993 Dodge cummins 5-speed DEAD!! ![]() |
Location: Help! I'm in an office park with its own network of freeways!
It's a '72? It already has disc brakes. Discs were standard in '71 across the light-duty line (10, 20, 30).
'67 C20--427 tall deck/SM420, 4.10 HO52 (Michigan has not been kind to the Old Man) '95 Caprice--355 LT1/T56/3.42 8.5" 10-bolt (daily driver, almost 300k on the chassis) '07 Outback--wife's car. 125k & counting. No head gasket or transmission issues yet. *fingers crossed* |
ok awesome. I have 2 72 C10 Cheyennes and they both have discs. I had heard a lot of people talking about drums on these so I just made an assumption. Are the brakes for this C30 the same as are what are on my C10's?
the motor is a 350/TH400 the guy says it is more than the truck needs. Either he doesnt know what real power is or that thing has a real steep gear...I just cant imagine a 350 that's as incredible as he is describing it. you guys think its a good buy @ $2500? I agree, from the pictures it looks like a sharp truck. Im worried about the wheels and tires though. putting 6 tires on it would be close to $1000 and thats hoping that those arent two piece wheels |
#11 | |
i guess the brake question is a dumb one considering my C10's are 5 lug not 8...but your saying that all '72 C class trucks(10,20,30) had front disc?
#13 |
All 1/2, 3/4, and 1-ton trucks--2WD & 4WD--had disc brakes from the factory in '72.
(I make no guarantees about a '72 K30 as GM did not make a mass-market 4WD 1-ton until '76 or so, but that's nitpicking.)
#14 |
why do you postulate that non of the wheels are the original 2 piece? because they look like radials not bias plys? i am sure it has its issues. he is asking $2500 and has been sitting on it for a while, im sure i could talk it down to 2000 or maybe even 1500. Mileage is unknown. I dont know much about 1 tons, what is a normal price for these things?
#15 | |
#16 |
There are tons of 2 piece duels. Most people try to replace them with one piece, but there are still lots out there.
#17 |
Rollin Coal
the reason for that is because it has a 4.11:1 or a 4.56:1 rear ratio, as they were the only two options in the eaton rear ends. but these trucks are a lot of fun under 60 mph ![]()
I have three letters to all these import guys: God-Made-Chevy 04 GMC Sierra 2500HD Duramax ![]() 1972 Chevrolet C-30 Dually Pickup stock? 350 SM465 four speed ![]() 1977 GMC K-35, TH-400, 4X4 450 horse 454(dad's) ![]() 1993 Dodge cummins 5-speed DEAD!! ![]() Last edited by hicktownhotrodder; 10-12-2010 at 09:26 AM. |
