Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 10-09-2010, 03:10 AM   #1
Yellow76
Yellow76's Avatar
Head help....again
I have already had a post about some different heads but recently i found some holley heads and i cant find alot of info about them i no it has 2.02 valves the part number is 12111 can any one help me get some more specs on these or any one running these? there is another number on top of the head and its 050302. Thanks
Yellow76 is offline   Reply With Quote
Old 10-09-2010, 11:14 PM   #2
Captainfab
60-66 Nut
Re: Head help....again
I briefly looked on line including Holley's website and apparently they don't offer those anymore. So I dug out an old 2005 Holley catalogue I have. It doesn't list any of those casting numbers as identification on the heads, but as fas as I know Holley only offered one set of small block heads. Here is the info it shows on them.
  • Valve Angle 20 degrees
    Intake Runner Volume 185cc
    Exhaust Runner Volume 68cc
    Combustion Chamber Volume 68cc
    CFM Flow @.500 lift measured @ 28" H2O
    Intake 223 cfm
    Exhaust 173cfm
    Intake valve Diameter 2.02"
    Exahust Valve Diameter 1.60"
    Spark Plug Angle Straight
    Deck Thickness .500"
    Exhaust Port location Stock
    Heat Crossover passage Yes
    Rocker Arm mounting Stud
    Rocker Stud diameter 3/8"
    Valve Guides Bronze
    Valve Spring Installed height 1.780"
    Max Valve Lift .600
    Valve Spring Force 132lbs
    Aluminum Head Weigt 30lbs
Old 10-10-2010, 01:25 AM   #3
Yellow76
Yellow76's Avatar
Ok thanks that helps alot so do you think some used are worth 350?
Old 10-10-2010, 03:07 AM   #4
mongoose
mongoose's Avatar
if they are usable.. ie not warped beyond a decking etc... 350 is a good price for them.
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 10-10-2010, 07:51 AM   #5
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
Exclamation Re: Head help....again
We really cannot answer your question on What Its Worth.
It's a policy of the board that you have to be a paying member to ask that question or post anything for sale.
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
Old 10-10-2010, 03:43 PM   #6
Yellow76
Yellow76's Avatar
ok i didnt no about that. With these heads work goo with this cam?http://www.lunatipower.com/Product.aspx?id=1984&gid=287
Old 10-10-2010, 04:04 PM   #7
mongoose
mongoose's Avatar
i believe that rule is if you're asking what it is worth and you're selling...
i can't see if asking if you're going to get ripped off against the rules.
Old 10-10-2010, 11:08 PM   #8
Captainfab
60-66 Nut
That cam will work fine with those heads. The real question is will it work with your short block and the intended useage of your truck. IIRC you have a stock 350 short block? Is that correct?
Old 10-11-2010, 03:17 AM   #9
Yellow76
Yellow76's Avatar
almost its a 355 headers those heads i have posted flat top pistions and plans of Performer RPM and holley 750 and that cam. For my tranny i have stage 2 shift kit with 2400 stall.
