Old 10-09-2010, 07:16 AM   #1
67gmcstepside
Rubber seal for outer axle -Spindel seal kit?
I started putting back my dana 44 front axle and there is a rubber seal than goes onto the outer axle that needs replacement. What would this piece be called and would any know where to purchase it? It didn't seem to be listed in LMC but I am not sure what its called to search for it. Would it come with the spindle seal kit? I am assuming it does.
67gmcstepside is offline   Reply With Quote
Old 10-09-2010, 10:54 AM   #2
1rocky
Re: Rubber seal for outer axle -Spindel seal kit?
Axle seals or hub seals?I just did a front pinion seal on my 73 K 20, I was surprised when pep boys had it in stock. I would expect a Napa to have them and the parts break down to identify the seals you need.
1Rocky
1rocky is offline   Reply With Quote
Old 10-09-2010, 12:24 PM   #3
67gmcstepside
NAPA ng, the guy had no idea. Might try PepBoys. Every now and then I get lucky. It looks the the part I need is part of the spindle kit. It slips on the the axle and goes around the flat -round part end of the outer axles.
Old 10-11-2010, 02:59 PM   #4
OLDCHEV4X4
OLDCHEV4X4's Avatar
NAPA spindle kit is SBK-1
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 10-11-2010, 03:30 PM   #5
Burt4x4
Burt4x4's Avatar
Spicer Spindal Bearing kit comes with that seal and a trust washer(hard plastic) plus bearing = 706527X
I have not try to buy that for many years but that was the number I have in my notes...
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 10-11-2010, 06:49 PM   #6
67gmcstepside
Thanks guys, my kit is on its way. Once I have that seal I can finish up the rebuild and get it under the truck.
