Old 10-09-2010, 08:29 AM   #1
BADPURPLE70CHEVY
406 Powered
BADPURPLE70CHEVY's Avatar
How bad is replacing turn signal switch?
I think i found my brake light problem. How bad is changing the turn signal switch? How much time?
70 GMC
68 c10
2002 silverado
72 4x4
BADPURPLE70CHEVY is offline   Reply With Quote
Old 10-09-2010, 08:59 AM   #2
bestchevyfan
Re: How bad is replacing turn signal switch?
Hey, dont know but i am going to try to replace mine so,i hope someone will tell us. Good luck. Buddy
bestchevyfan is offline   Reply With Quote
Old 10-09-2010, 09:05 AM   #3
sameyrasmea72
sameyrasmea72's Avatar
I don't think it is that bad, unless it is a tilt.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 10-09-2010, 11:50 AM   #4
pat 70/71
pat 70/71's Avatar
Its not bad at all. take your time and it will be fun. give your self all the time you need . pull the wheel and get after it! cheers, Pat
pat 70/71 is offline   Reply With Quote
Old 10-09-2010, 01:05 PM   #5
BADPURPLE70CHEVY
406 Powered
Thnx.......
70 GMC
68 c10
2002 silverado
72 4x4
Old 10-09-2010, 02:50 PM   #6
Maxxd07
Maxxd07's Avatar
Really easy compared to anything newer, only "special" tool needed is a steering wheel puller. Doesnt hurt to disconect the battery to keep the horn from blowing in case you ground it. Time wise 1-2 hours is pretty generous time. Good Luck!
Couple 80s
Couple 70s
One 68
Maxxd07 is offline   Reply With Quote
Old 10-09-2010, 08:43 PM   #7
Old Yeller 1970
DON'T TREAD ON ME
Old Yeller 1970's Avatar
Been there done that. Steering wheel puller and a couple of hours will have you done.
Old Yeller
Old Yeller 1970 is offline   Reply With Quote
