Old 10-09-2010, 10:17 AM   #1
Davetopay
NP205...all it took was a little wheelin'.....
....and now she's a leaker.
I'm looking around at rebuild/reseal kits on line. Most seem to be about the same price, but I just don't know which one would be the best quality. Any previous experience?
Davetopay is offline   Reply With Quote
Old 10-09-2010, 10:46 AM   #2
1rocky
Re: NP205...all it took was a little wheelin'.....
maybe look for a good take out that does not leak
1Rocky
1rocky is offline   Reply With Quote
Old 10-09-2010, 11:42 AM   #3
Davetopay
1Rocky
50-100 dollars for a seal kit, vs 300+ for an unknown condition unit...I'll go with the kit. Around here (DC area) you don't find used/takeoff parts like other parts of the country.
Old 10-09-2010, 12:09 PM   #4
1rocky
10-4 on the west coast you can sometimes pick up a complete rolling frame for a 100 bucks, I have sold a few just to clean up the yard.
1Rocky
Old 10-09-2010, 01:22 PM   #5
nyncompute
nyncompute's Avatar
If you're going through the hassle of pulling the thing, you might do well to consider just replacing the seals. I just did that chore myself and it wasn't too bad. That way you know the unit and there wouldn't be any surprises with something new.
1972 K-10 SWB Cheyenne
nyncompute is offline   Reply With Quote
Old 10-09-2010, 01:47 PM   #6
turp mcspray
turp mcspray's Avatar
I just bought a seal and gasket set a couple days ago, at the local truck part/driveline shop. $25.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 10-09-2010, 02:11 PM   #7
Rdrdave
Broke and still trying
Rdrdave's Avatar
Thumbs up Re: NP205...all it took was a little wheelin'.....
I've never rebuilt one but it can't be more difficult then rebuilding and engine. Here's a site that shows the rebuild process, w/pics! Good luck.
http://okcnetworks.com/bronco/205/np1.htm
Rdrdave is offline   Reply With Quote
Old 10-09-2010, 03:44 PM   #8
Billhilly
Billhilly's Avatar
Dan at Quad 4X4 has all the bits, and manuals to do the job - http://quad4x4.com/New_Process_NP205_Parts.html Helpful guy with the knowledge to back it up. Give him a call.
1972 K2500 Long Box
400/350
Billhilly is offline   Reply With Quote
Old 10-09-2010, 10:30 PM   #9
nyncompute
nyncompute's Avatar
if it just leaks, there's no need to rebuild anything, Barring finding any surprises, you just need to get the seals and replace them.... easy peezy
Old 10-10-2010, 01:32 AM   #10
chisler
chisler's Avatar
On the output shaft yoke seals make sure you stay with the... NATIONAL...brand as they are of the double lip style... CR will be a single lip,and make sure you check the yoke for ...o ring grooves as well...which may require a speedy sleeve or replacement of the yoke... front yoke is the lowest point on this style transfer case
chisler is offline   Reply With Quote
Old 10-10-2010, 07:47 AM   #11
Davetopay
EXACTLY the info I was looking for! Thanks Chisler!
Old 10-10-2010, 11:42 AM   #12
Redcap
Exactly.
Redcap is offline   Reply With Quote
Old 10-10-2010, 03:13 PM   #13
chisler
chisler's Avatar
Glad I could help out,down the road I know you would do the same!!!!!!
Old 10-10-2010, 11:45 PM   #14
Davetopay
Since it is just the front output which is dribbling, can it be done with the unit in the truck? Or do I have to drop that heavy mofo?
Old 10-11-2010, 01:20 AM   #15
chisler
chisler's Avatar
You do not have to remove the transfer case,but the cross support needs to be removed to acess the flange bolts,I did mine before I went elk hunting....took me just over a hour to do it....pull the drive shaft....put a floor jack under the transfer case to support it....drain the unit....then remove the transfer case cross support.....undo the yoke bolt......use pry bar or pipe wrench to hold the yoke while you do this.....remove the flange bolts...and then remove the flange..... pop the old seal out...and in with the new.....but check the yoke for wear as I said before.....take your time and get a buddy to help if you can.......I WAS IN A RUSH TO GO HUNTING AND SHOOT A ELK......LOL
Old 10-11-2010, 07:57 AM   #16
Davetopay
Very cool. Thanks for the info! Now it just comes down to if I FEEL LIKE doing it my self in the street, or letting the shop at the end of the block do it and saving myself a head ache.
