member
WTB Driveshaft
I need a driveshaft that goes with a dana 60 rear. What do you have? $$ ? Any condition. Thanks
John
1967 C/K10 Chevy Panel 1968 C/K20 Chevy Pickup 1968 C/K10 Chevy Suburban 1941 Chevy Sedan Delivery 1960 Chevy Sedan Delivery 1972 Camaro SS 396 #s matching 1971 Harley FX Superglide Last edited by olblue60@aol.com; 10-10-2010 at 08:20 AM. |
Re: WTB Driveshaft
What year truck?
what trans and are you running ?, 2wd or 4wd ,? short or long bed..? 2dr or 4dr? single or 2 piece? Last edited by 70BLAZERX2; 10-10-2010 at 05:27 PM. |
member
Re: WTB Driveshaft
I'm looking for the fat driveshaft,4 1/4 inch ? Diameter. I have a long bed truck but what i'm needing is just the end at the rear cut off a whole driveshaft or a whole driveshaft for a longbed. I have a half ton shaft that could be cut and a 3/4 ton end welded or a whole driveshaft for a 4x4 with 205 transfer case / dana 60. Thanks
john
1967 C/K10 Chevy Panel 1968 C/K20 Chevy Pickup 1968 C/K10 Chevy Suburban 1941 Chevy Sedan Delivery 1960 Chevy Sedan Delivery 1972 Camaro SS 396 #s matching 1971 Harley FX Superglide |
Re: WTB Driveshaft
you can get a 348 u-joint at any parts store..this is small on one end and large the other way..Will save you a drive shaft mod..I just did this ,1/2 ton rockwell case to 3/4 shaft in a 69..same thing.
I got mine at oriellys and was 18 bucks. |
Re: WTB Driveshaft
I have a 3/4 4 speed complete driveshaft out of a 85 with a 14 bolt. Will that work?
Pm me if it will........ Thanks, Steve |
member
Re: WTB Driveshaft
70blazerx2 Thats exactly what I'm doing. Thanks for the info.!!!!
qsilver I dont know the measurments of the 14 bolt, but thanks for answering my post. I think that I found my solution.
Re: WTB Driveshaft
split u-joint is alot cheaper than getting a shaft done..
Re: WTB Driveshaft
np
