What e-fan relay did you use????
I was working in the garage yesterday and decided to mess around with an electric fan I got from a 2005 Mustang. I took the positve and negative leads and connected them to my battery posts to see how much air it wld pull. Worked awsome. I remeber seeing a thread about an e-fan install and was wondering what relay and tempsensor set up was used and if it worked well?
Re: What e-fan relay did you use????
How's this?
![]() need more help, just ask
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 10-10-2010 at 08:23 PM. |
I used a Derale adjustable control unit with the screw in type temp sensor, instead of a push in, probe type.
I got the cheapest relay/temp controller that Jegs had. I think it is "Perma-Cool" brand. It features a temp probe that slides into the radiator fins. It can control/power two fans up to 20amps. I use it for two 12"ers and wired the AC turn on to a switch with ignition hot so I can manually turn on the fans when I want.
Pros: Complete kit. Can power two fans. Has an AC turn on wire Cons: All the wires, including the temp probe, are hard wired to the controller. This makes installation way more of a pain and the temp probe wire is pretty short, limiting how far from the rad you can mount the relay. No variable speed/soft start. (Some $200 controllers feature this) I don't like the external temp probe. Next summer I want to run an actual rad coolant temp sensor but since the probe is hard wired I think I need a whole new unit. |
![]() Join Date: Nov 2007
Mario - I have a Flexalite controller that I'm going to sell soon. Pretty sure its this one --> LINK
PM me if you want more info. EDIT: added link. Posted via Mobile Device Last edited by AJs72K5; 10-12-2010 at 09:10 PM. |
I bought a sending unit from summit that provides ground from 185 on 170 off and I used a relay for a pt cruiser and pigtail from junkyard it works great
Collector of Projects
Do you have a PN for the sending unit?
