Old 02-27-2003, 10:41 PM   #1
PHOENIX
Axel Identification (numbers are where?)
What numbers tell me what the rear end is?
Where are the numbers on the axel?
I have a 1983 C10 w/ a 10 bolt rear end.
I want to figure out what I have.
I also plan to count the rotations, but I would like to check the numbers.
thanks
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 02-27-2003, 11:58 PM   #2
RockHQ
ROCKET POWER!
RockHQ's Avatar
Pop the diff. cover open, the ring gear will have a set of stamped numbers on it, followed by "GM x y" where x and y are the teeth count of the pinion and ring. Divide the latter with the former and you'll have an exact gear ratio.
What did i do last nite?
I had a wonderful time,
That's what they tell me
1979 C-10 shortfleet: Olds 350, Th400, 12 bolt
Current project: 1969 Olds 455 W-30, needing a rebuild
RockHQ is offline   Reply With Quote
