10-10-2010, 02:24 PM | #1 |
Identify this transmission please
I can get this transmission real cheap "free". The guy said its a 2004r trans. Was wondering if someone could look at the pics an tell for sure. The only numbers I could find are 8663550 an MD8 the tag is gone off of bellhousing. Also will this fit a 350 chevy motor? Thanks Randy
10-10-2010, 02:30 PM | #2 |
its all about the +6 inches
Re: Identify this transmission please
the only thing I can tell by those photos, is it won't bolt up to a small block. Looks like it may be out of a 2.8 powered S-10 or camaro.
10-10-2010, 02:34 PM | #3 |
Thank you that's what I was afraid of. That's for the quick response.
Posted via Mobile Device |
10-10-2010, 02:36 PM | #4 |
I just put one in my Sons 69 long fleet and the only problem we had was we had to file down the lip on the front of the center of the Torque Converter so it would slip inside the back end of the Crank Shaft. If you do get it and it is a 2004R make sure you do that before you try to slip it into the truck. My Sons truck runs great and is very driveable at 65 and 70 MPH. In fact I like it so much that I am putting a 700R4 into my Younger Sons 64 Short Fleet. If you could take a picture of the passenger side of the tranny it might help in the ID of the Tranny.
On the 700R4 the TV Cable is on the drivers Side about half way back and the 2004R is on the Passenger side up front on the tranny. Im sure there are other ways to figure it out. The one thing that has me scratching my head is the long protrusion in the middle of the Torque Converter. The one I had was only about an inch and a half long but that one looks to be pretty long. JRBECK64 |
10-10-2010, 02:38 PM | #5 | |
........................ __ ............._______|__\____ ............|_({})______({})] ................(O)..........(O) |
10-10-2010, 02:39 PM | #6 | |
Thats what its out of. 2.8 v-6 s-10 or camaro
MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=423629 1969 custom/10 swb--SOLD 1968 swb 50th anniv.--SOLD 1967 camaro ss/rs..LS-6-speed, 16-year long project 1956 chevy nomad 1955 chevy 210 2-dr sedan 1978 el-camino ss 1-owner |
10-10-2010, 02:42 PM | #7 |
Look What I found
Description This is a Professionally Rebuilt second generation 700-R4 (MD8) Automatic Transmission that will work behind any 1982-1992 2.2L 4 Cylinder, 4.3L V6, 5.0L V8, 5.7L 350 V8, or other GM, Chevy and GMC applications. Used in such models as Astro Van, Blazer, Camaro, Caprice, Corvette, Impala, Jimmy, S10, S15, Sonoma, Safari, Suburban, Syclone, Full Size C/K Truck, Typhoon, Van, Yukon and many more. All transmissions come with a 6 Month Unlimited Mile Warranty with the purchase of a new torque converter. This transmission contains a Alto 9 Clutch 3/4 stackup (The ¾ Clutch pack is one of the biggest weak spots of the this transmission, this stakup allows the load to be to better distributed on the increased clutch apply area of the 9 clutches instead of the 6 clutches OEM); Borg Warner high energy band (exceeds OEM quality); all new high quality Borg Warner clutches (exceeds OEM quality); new pump, tail housing, case and other bushings; new gaskets, seals, molded pistons, and metal clad seals; new pump vanes; new accumulator pistons; New TransGO Valve Body Seperator Plate; This Transmission also comes with a TransGO shift correction kit. This kit replaces weak valves springs, accumulator springs, servo springs, and fixes other issues with this transmission. Overall the kit helps increase the life and durability of the transmission. We have a many different models of the 700R4 transmission available. We also have many options for upgrades available, or custom high performance applications options, email us for details. If you are not sure of what type of transmission you have or want to know if this will work for you just email us with the vehicle information. Read more: http://chicago.ebayclassifieds.com/p...#ixzz11yzX22Pl I would get it If I were you but you may want to take an etching of the back of your Small Block before you get it to make sure the holes line up. I would also look at the specific application for that Torque Converter. JRBECK64 |
10-10-2010, 02:45 PM | #8 | |
The transmission in the pic WILL NOT fit a chevrolet small block.
10-10-2010, 02:56 PM | #9 |
That transmission absolutely will not bolt up to a V-8 or 4.3 V-6. It fits the 60 degree V-6 and some of the 4 cylinder engines. The tag you read sounds like a generic one the rebuilder puts on all of his transmissions.
If it really is free, and you are determined to take it, just make sure you have some place to store it until you can sell it or give it away. Ray |
10-10-2010, 10:17 PM | #10 | |
JRBECK64 |
10-10-2010, 10:31 PM | #11 |
Restoring it $200 at a time...
The pan on a 200-R4 has "METRIC" stamped into it in 1" high letters.
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society '68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327. DD '09 Pilot Weekender '65 Skylark 300-4V-4 speed Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine. Son's '04 F250 SuperCab 6.0 |
10-10-2010, 11:44 PM | #12 |
Truck and auto performance nut
thats no 200-4r.....or at least it looks nothing like mine.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
