72 K10 4X4 Exhaust Kit
I need to replace the exhaust on my 72 short wheelbase 4x4. It has headers I plan to keep. Are there dual exhaust kits available that work with a little cutting or welding or am I better of having a custom system installed locally?
I'm interested in 2 1/2" pipes. Gary |
GEARHEAD
Re: 72 K10 4X4 Exhaust Kit
I just bought a hooker kit through summit racing for my 4x4 jimmy. I wouldn't recommend it. They are supposed to send me a new tube to replace one that is bent wrong, the next 2 tubes were not expanded enough to fit over the next section, I won't know if there are other issues until I get the new pipe and can try to finish the install.
On my other truck I'll use a different kit.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff |
Thanks.
I'd be interested in how the rest of the install goes when you get the replacement pipe. Gary |
![]() Join Date: Jan 2005
I have the LMC system, it fit great on my stock manifold Blazer. It is made for long-bed trucks you just cut down the intermediate pipes for your truck. A few others around here have the same system.
-Chris Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid. Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals... |
Thanks Chris I'll take a look at LMC. I'd be curious how difficult converting the kit to headers may be.
Thanks Gary |
Back in the sticks
I got this kit for the Blazer, only really used the over the axle parts, but it worked out fine. I had already had 90's bent for the manifolds and was running 6 foot of straight pipe out to mufflers.
http://www.jegs.com/i/Dynomax/289/89007/10002/-1
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
