Electrical class 101!?!?!
Hey guys. I recently found a starter button (2 post) in my garage and I plan on installing it in my blazer instead of the regular ignition ie. Key method. Have any of you guys installed one and what wires/switches will need to be hooked up. The truck is running a mechanical fuel pump
Thanks Andrew |
Re: Electrical class 101!?!?!
I would drop this question on the electrical section, those guys really know their stuff. I, on the other hand know nothing
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
Great observation! I’m in concurrence.
Back in the sticks
Are you going to keep the stock ignition switch in the dash? It also depends on whether you have an automatic(neutral safety switch) or manual transmission. In either case you will use the purple coming off the back of the ignition switch to go to one side of the starter and I think the Pink. I'll have to do some testing to see if it will work like that. You might even get away with just the purple and a ground.
Problem is the on and off function of the ignition switch. Part of it is on, part of it is cranking. If you remove it, you'll have to still complete the ckt somehow.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
