Old 10-10-2010, 11:05 PM   #1
GMC87
Serpentine belt squeal issue A/C compressor
So my serpentine has been squealing on my 87 (454). After replacing the belt checking the tensioner I found out today that it is actually the A/C compressor pulley will lock up when I turn the heater on????????
Am I missing something here why does the heat effect the A/C compressor?
And is there any way to rebuild the pulley?
I assume there is a clutch of some sort in it.
When the heat is off it spins just fine no squeal as soon as I turn the heat on I can see the pulley stops and belt is just sliding over it. The belt is new and as tight as it can get.
Any suggestions??????????????
GMC87 is offline   Reply With Quote
Old 10-10-2010, 11:19 PM   #2
CaliDude76
All About the BOWTIE
CaliDude76's Avatar
Re: Serpentine belt squeal issue A/C compressor
Sounds like you might be having an issue with the HVAC Control head itself... are you sure your not putting it in defrost mode?.. that does activate the compressor as well...
.. does your compressor normally work otherwise...?? if you turn the actual A/C on..? sounds as if your compressor is seized completely... and somehow getting activated by the HVAC head unit....when in heat mode
If you haven't already... and I could be preaching to the choir here... but just unplug the compressor....
CaliDude76
"... Being "SQUARE".. is where it's at...."
Proverbs 15:30 .... "A Cheerful look brings joy to the heart, and good news gives health to the bones..."
Be exceedingly blessed today, my friends!...
CaliDude76 is offline   Reply With Quote
Old 10-10-2010, 11:24 PM   #3
GMC87
It will squeal in A/C and in defrost.
If I can just up plug it for now that would be fine, I can address a proper fix next summer when I need it.
Old 10-10-2010, 11:28 PM   #4
CaliDude76
CaliDude76's Avatar
..Yeah, that might be your best bet.... it does sound like your compressor is seized.... the plug is usually located right at the front of the compressor between the pulley and the body of the compressor.... should have no problem disconnecting.... good luck!
CaliDude76
Old 10-10-2010, 11:32 PM   #5
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
the a/c is supposed to run in defrost for sure, not sure about heat though.... I will start the truck up tomarrow and see what my truck does when I turn on the heat.
Clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 10-11-2010, 08:37 AM   #6
GMC87
I unplugged it this morning on the way to work, no squeal.
Looks like I will leave it that way for the winter and deal with it in the spring.
Thanks of the replies.
Old 10-11-2010, 12:45 PM   #7
Slonaker
Insert Witty Text Here
Slonaker's Avatar
On my '86 I was having problems with the compressor clutch engaging when I had it on "vent." Later it was engaging on all settings except "off." I recently replaced the dash control, and that fixed all of those issues.
It sounds like you need a new dash control and a new compressor.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 10-11-2010, 08:15 PM   #8
CaliDude76
CaliDude76's Avatar
^^ x2
CaliDude76
