10-10-2010, 11:42 PM | #1 |
84 Crew Cab blinkers/flashers not working
Alright guys when i turn on my headlights none of the dash lights are lighting up and neither blinker even attempts to work for the hazards or blinkers.... is there a fuse for it im missing or maybe my switch going out? i replaced the actual flasher relay...
10-11-2010, 12:15 AM | #2 |
BAD BOW-Silverado XST
Re: 84 Crew Cab blinkers/flashers not working
When turn signals don't work, usually you have a burned bulb or bad ground. The turn signal switch could be broken too. You can find a replacement in the help section at most part stores.
