10-11-2010, 12:28 AM | #1 |
what angle did u cut your z?
was wondering what angle you guys with z'ed frames cut it at? also where did u cut it, how far past the cab? thanks guys
10-11-2010, 01:23 AM | #2 |
Re: what angle did u cut your z?
when i Z'd my old frame i did it just behind of the shock stud and i cut mine straight up and down... heres a picture.
Justin
[PROJECT] FnLow69- 69 C-10 Full frame & layin' doors [PROJECT] Laidout53 - 53' Dodge Pickup, Full Kustom Build [PROJECT] "Hot Rod" 1931 Model A Bonneville style "Dream as if you'll live forever, Live as if you'll die today" ~ James Dean |
10-11-2010, 11:08 AM | #3 |
Junior Member
I did a 3.5" Z with a 74 degree cut. Moved it forward an inch or so. It's been a while but I remember using poster board to simulate the cut and this was the angle I came up with. Just remember if you use the 74 degree angle and do more/less of a Z it will affect how much it moves the xmember forward.
Here's the best pic I have of where I cut the frame. |
10-13-2010, 02:58 PM | #4 |
I assume you cut the front at the same angle correct? so the rad support is in the right spot?
10-13-2010, 03:54 PM | #5 |
You don't have to. You can cut it vertical & just remove the necessary material to keep the dimensions the same.
10-13-2010, 04:13 PM | #6 |
Does anyone have any pics of how they cut their core support mounts? Does it matter where you cut it at?
10-13-2010, 07:34 PM | #7 |
The cut is specific as you have to be able to drop the radiator w/o interfering w/the steering box.
10-13-2010, 10:10 PM | #8 |
Gonna be running a pb xmember so steering box wont be an issue
10-13-2010, 10:18 PM | #9 |
drop member and a Z? what size wheel/tire combo u plan on running?
10-13-2010, 10:34 PM | #10 |
dropmember and bodying it to the rockers...gotta move body mounts and core down
10-13-2010, 11:05 PM | #11 | |
Junior Member
Added pic of where I cut mine off... Just cut the frame horns off just behind the core support and drop them down. No biggie. You going to lay rockers with or without pinch? Last edited by 68laydout; 10-14-2010 at 01:42 AM. |
10-14-2010, 05:59 PM | #12 |
Thanks for the pic...about where I was looking to do mine....mine doesnt have to come down far at all either.
Plan is to lay rocker and fold the pinch under |
10-15-2010, 03:14 AM | #13 |
all these pics an info is a lot of help thanks everyone
