rocker panels cab corners
I am totally new to this site, that is because I never owned a c-10 before
Just ended up with my wifes grandfathers 71 c10 , it has been a farmtruck all it's life . All bodyparts need replaced , allready found all used parts . engine/drivetrain is good,stripped truck down to just the cab and frame Cab needs rockers inner and outer +cabcorners and cabsupports .Just picked up these parts , I have a mig welder, But I do not have a lot of experience welding sheetmetal Could use some advice/pics on how to cut out the old rockers /corners/cabsupports and weld in the new ones Thanks Elbert Koster Canada |
Re: rocker panels cab corners
http://67-72chevytrucks.com/vboard/s...=339960&page=4
Here is a thread on replacing them but do a search and you will find lots. Also welcome to the board!!!!! Lots of info here.
Kerry My build thread. http://67-72chevytrucks.com/vboard/s....php?p=3657823 1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears 1988 Chev Extendacab 2010 Honda VT1300CS Sabre 2005 Buick Rendezvous wife's ride |
Master Procrastinator
welcome to the site, you will find anything you need on here, also in Penhold there is a place called scotts super trucks, he has everything you'll ever need new and used for our trucks, also where are the pics?
![]() 20 Duramax tow pig 68 2wd short stepper project 77 2wd short fleet beater 52 short project |
