Six in a row makes it go...
![]() Join Date: Mar 2009
Did I install the front sway bar upside down?
Can anybody tell from the pic? Something doesn't seem right...
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
Truck and auto performance nut
Re: Did I install the front sway bar upside down?
not sure... but I don't think it would work upside down?
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
Here's a pic of the factory swaybar in my 70 for reference. It kinda looks like you've got it installed right. It could be that you've got to put the weight back on the wheels to know for sure.
![]() Last edited by Indyuke; 10-11-2010 at 12:22 PM. |
Junior Member
It looks correct to me. It seems the angle of the A arm bushing and the tip of the sway bar would be hard to align and tighten down without the weight of the truck on the suspension. That may be why you are having doubts.
70 C/10 LWB 250 ![]() |
#5 | |
It took a little doing to get the last bushing down on the control arm. I had to use a long bolt to drag it down. Maybe I need the entire vehicle weight on the suspension? ![]()
#6 | |
72 Cheyenne Super 1/2 LWB White/Dark Yellow 07 Avalanche 2LT 74 Sleek Craft Rebel Jet Boat W/Pontiac 400 Last edited by OhOneWS6; 10-11-2010 at 01:18 PM. |
I had problems with fit/mounting the sway bar I bought from cpp. I called there tech support and they told me it needs to be installed at ride weight so basicly its like the last thing to install, but I think Im still gonna come up short. Have to wait and see when i get to that point like 3 years from now lol.
Eric 70 CST10 long bed in pieces also factory air and cruise(the project) 18 Silverado crew cab 5.3 4x4 My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=402166 |
I think you guys are right - there's just not enough weight on the suspension. Thanks for your help.
